Old 11-07-2009, 07:17 AM   #1 (permalink)
Silverbullet114's Avatar
Member Number: 47454
Question HELP Fuel Leak Right By Fuel Rail
As everyone knows I just went the route of big turbo last month. Still getting all the kinks worked out, but this seems to be my last problem knock on wood. I noticed that I had a leak the other day when I popped my hood and seen everything on the left side of the injector cover reaking of fuel. This only happens when the car is running because If I let the car sit for a day it becomes bone dry? Also when I put on my heat it stinks like a gas station and I use alot more gas now. Has anyone ever experienced this problem?
"It's All About Reputation"
Silverbullet114 is offline   Reply With Quote
Old 11-07-2009, 07:31 AM   #2 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
Trader Rating: (12)
you better get that taken care of asap before your engine back catches fire! it sounds like a leak if you removed the rail or did return line you probably didnt seal the fittings good enough get it fixed asap
GT3076R-AEM EMS-DP VARI-COOL
WWW.MYFLORIDASRT.COM
SRTMIAMI is offline   Reply With Quote
Old 11-07-2009, 07:47 AM   #3 (permalink)
I thought it might of been the return line as well thanks for the reponse
Old 11-07-2009, 07:54 AM   #4 (permalink)
SRTMIAMI's Avatar
Trader Rating: (12)
if youre not sure have someone rev your engine so you can see where its squirting from...
Page generated in 0.11593 seconds with 13 queries
