Quote: Originally Posted by
Bactine
I'm hoping the afrs might be off because of a bad ground or something but I'm not going to mess with anything until I get a reading with the serial cable because that will tell me for sure what my afrs are then I can compare it to the gauge readings.
What I'm asking is, it doesn't seem normal to be going this lean with so little boost. Could it be a fuel pump or fuel filter causing something like this? I literally shit my pants when I went WOT the first time with a wideband and saw 13.0
I was just going to suggest Logging the serial output.
I always record the log on the laptop instead of trying to eyeball a gauge when tuning. Its much easier that way and more accurate.
With a stock tune and 17-18psi you should be in the low 11.0x past 5000rpm.
I wouldn't freak out until you've varified the A/F. Be sure to properly calibrate the sensor too for good measure. I'd also disconnet the battery to reset LTFT just in case LTFT was pulling fuel at WOT.
If A/F is still in the 13.0,,you should check fuel pressure at WOT. It should be 58psi +/-5psi and stable. If it drops at all it could be the pump or a restiction. If the pressure is stable but lower than ~50psi the regulator might have issues(rare but possible)
Also, an exhaust leak ahead of the O2 can cause a false lean. If you have the wideband installed after a cat, that would cause a false lean reading too.
ps Bottleneck isn't an issue until about 350whp. Returnlines just dump fuel and imo probably just masked ChadSRT other issues.
