#1 (permalink) |
![]() Join Date: Feb 2009
Member Number: 70601
Ok this winter I'm goin to run e85 for next spring. I'm goin with walboro 255, Rewire kit, and pnp 750 injectors and AEM wide band with a tune form Pt-performance. Should I add anything or am I good?
Thanks
| Sponsored Links | |
Advertisement |
#7 (permalink) |
![]() Join Date: Feb 2007
Member Number: 51197
Nah, my return line is installed and it acts exactly like the stock one. You can just set the fuel pressure to 58psi and not hook up the rising rate. So your fuel pressure WON'T rise with every 1lb of boost. Kind of defeats the purpose, but I didn't need the extra fuel and couldn't pass up the deal.
I believe Nacho did a straight E85 build on stock turbo, using 1000CC injectors or something. Either way, 31xhp is about where it's going to end with stock turbo. You'd need to upgrade to an E1/SST/Shocker/Upgraded Stocker to see HP gains past that. |
#8 (permalink) |
![]() Join Date: Aug 2007
Member Number: 57024
agree with adionik, and its ALWAYS good to have extra fuel with e85
Stop messing around with vendors who dont care, Shop PTP and be treated like family. ![]() To make a purchase please go to www.pt-performance.com Shop hours are 9am to 7pm Monday-Saturday Shop number 253-277-3843, Shop cell 253-653-3843 |
#10 (permalink) |
![]() Join Date: Mar 2004
Member Number: 8662
TADA!
I did use Injector Dynamics 1000CC's NO RETURN and a 255 with a pimp ass rewire done by Modified By KC (www.mkcperformance.com). I tuned with an AEM EMS. I did nothing to the intake or exhaust excepting an AGP DFIC, AGP 3 inch CAI and AGP Hardpipes with the HKS SSQV. That was the extent of my bolt ons for the intake. I have an MPx 3" TBE Single exit, and used the MPx 3" O2 housing, both are top quality parts. With this set-up @ 30ish PSI I was *spiking* 308/397. With port work a Throttle body, and some cam gears I could have seen 320-330 tops. More likely 315-320. With 420-440 Ftlbs. On the above set-up I had no issues maintaing top of my run group staus at the road course. I picked up so much off the corners, but had to manage RPM range very tightly. E85 around here is 1.71/gal to 2.31/gal within a 75 mile radius of my home. I have access to 4 E85 stations within 20 mins of my home. 15 or so within 75 miles. I was using Sunoco 110 - @ 8.51/Gal Available 2 places within 75 miles. yeah, no brainer for my switch. I went a little wild with my set-up and took lots of pics. MKC Presents NachO_SRT Oh yeah, my new Daily driver is a sub page (2009 STi) I'm working on refitting the car for some Time Attack tries next year, looking to get at least some competitive track time under my belt. This winter: New Engine, New brakes, First SRT to use Pro-EFI?...We'll see. Anyhow, good luck on the E85 switch, and as with anyone on this site, if I can answer your question, I'll try, just drop me a PM. NachO |
#11 (permalink) |
Member Number: 56748
How much is E85 running anyway?
-2004 N. SRT-4: Garrett T04Z 67mm
Redspeedfreak, DCR, Rage-tek, AGP, etc. -2000 Dodge Neon ES: Downgraded close to stock. SOLD 5/20/10. AKA lblackneon. |
#12 (permalink) |
![]() Join Date: Aug 2008
Member Number: 67116
The closest station to me is 42mi's away, so I've been switching back and forth from E85 and 93. Whenever they finally bring a station closer I'll run it all the time.
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-DCR automatic setup-dss axles-boomba fuel rail-boomba mounts-boomba throttle body-3in side exit exhaust- spearco intercooler- Borg Warner S360RS and PFI/Kevin Warren tubular manifold setup
Soon to come, my high compression build New turbo setup and transmission setup |
#14 (permalink) |
On average about $.50 cents cheaper than 93 Right now it's $1.89 and 93 is $2.55 I'd like to run E85 but I don't think I have enough fuel for it. Stage 2 injectors with a 255 and return line. I could probably run a 50/50...but mehh... |
#15 (permalink) |
![]() Join Date: Jun 2004
Member Number: 12457
lol who said 400 on the stocker. thats a little optimistic
maybe on 2.6 stroker and timing to hell, maybe then 400 on the stockergood thing about e85 is i just paid $18 to fill the tank!!!
| Thread Tools | |
| Display Modes | |
