Old 10-13-2009, 06:56 PM   #1 (permalink)
svtsrt's Avatar
Member Number: 41942
Trader Rating: (15)
Default gas gauge might be off
I just replaced my fpr and fuel pump. When I did this, I had about 1.5 gallons of gas left. When everything was installed and I started the car, it said I had 3.5 gallons in the tank. So I filled the tank with 3 gallons to see if it was reading correctly and the gauge registered 6.5 gallons.
I think I damaged the gauge in the tank though. When I filled up today, the gauge read 3.5 gallons before and I got 10.3 gallons of gas to fill the tank.
If it's broken, can I just replaced that arm on the stg3 pump assembly? Can I do it with the stg0 assembly since it's just the gauge?
05 SRT-4
-Mopar stg3, Mopar BOV, sts, exhaust, CTI hotside pipe, JBM cc, Maxxfab dp w/ cat, AEM uego wideband, Aeroforce gauge-
svtsrt is offline   Reply With Quote
Old 10-15-2009, 08:16 PM   #2 (permalink)
Member Number: 3578
I believe twisting the whole fuel module to the left may fix your problem. There is a little play when the module is in 'correctly'.
Just loosen the retaining ring enough to twist the module (making sure the alignment tab is in at the top)
**Scammed by Resin8** NEX coilover groupbuy
2004 SRT-4 Black
1998 Neon R/T Turbo Black
98rt_canadian is offline   Reply With Quote
Old 10-16-2009, 07:31 PM   #3 (permalink)
svtsrt's Avatar
Trader Rating: (15)
I think I twisted too far to the left. I didn't feel the alignment tab in the gas tank before I tightened everything up. Gotta burn the gas and then retry it.
Page generated in 0.19351 seconds with 13 queries
