Old 02-14-2008, 11:53 PM   #211 (permalink)
Member Number: 59801
Quote: Originally Posted by josB_srt4 View Post
heres a pic of mine with ss braided line
is that all u gotta do for the bottle neck fix?
SourSkittle is offline   Reply With Quote
Old 02-15-2008, 04:31 AM   #212 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (17)
No, if you read the first thread and look at the pic, you are replacing the fuel pickup line, so you have to either reattach it to the stock line (which is metal, so you have to do flare fittings or something like that) or run a new line all the way to the rail.
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Old 02-18-2008, 10:14 AM   #213 (permalink)
gq4life's Avatar
Member Number: 10297
pickup line meaning one sitting in tank on suction side of pump>?
i just bought ll the stuff to fix bottle neck..
from pressure side of pump out canister to fuel rail..
inline filter too.. FPR sucks,.. it leaks.. damn 25 cent o-ring
theres nothing else I have to replace?
getting rid of this cap on fuel pump the bottle neck fix isnt it
gettin rid of stock FPR/filter just to prevent leaks
2004 Dodge SRT-4
AGP 50trim Turbo
Old 02-27-2008, 09:10 PM   #214 (permalink)
slyder's Avatar
Member Number: 36768
Trader Rating: (65)
Nice touch with that 30degree angle piece to reduce the bending of the hose. I'm going to do that with mine, never would have thought of that and great pic answered some questions I had.
Thanks,
Slyder
slyder is offline   Reply With Quote
Old 02-27-2008, 11:46 PM   #215 (permalink)
gq4life's Avatar
Thanks,
Slyder
damn it.. that wasnt 45 degrees
Old 04-17-2008, 10:52 PM   #216 (permalink)
Member Number: 44126
quick question what happens to the pump sitting in the blue rubber at the bottom of the canister does the pump just hang inside the canister or what pics would be nice thanks
JCHRISTENSEN is offline   Reply With Quote
Old 05-31-2008, 08:36 AM   #217 (permalink)
Member Number: 58959
does it matta how close or far the fuel filter is from the pump???
SSalexSS is offline   Reply With Quote
Old 05-31-2008, 09:31 AM   #218 (permalink)
slyder's Avatar
Trader Rating: (65)
Nope doesn't matter where, I was going to mount mine to the frame rail.
If you got a nice AN you could mount it in the engine bay area. Very easy access to change the element
Old 05-31-2008, 11:12 AM   #219 (permalink)
so do i hve to reuse the stock fuel line or just buy fuel injection line?
also i have a boomba fuel rail how do i connect the ss line to that its -6 the ss line
Old 05-31-2008, 11:16 AM   #220 (permalink)
Member Number: 46363
Trader Rating: (37)
Take off the fitting on the rail and replace it with a -6an male/male union. The rail is tapped -6an.
Bryan Tracy
04 Silver SRT4 - Parted and Sold
05 Aero Blue SRT-6 - New Toy
ImportLabSRT4 is offline   Reply With Quote
Old 05-31-2008, 11:28 AM   #221 (permalink)
what about to the stock feedline i keep that correct? how do i connect the ss line to it!
Old 05-31-2008, 11:58 AM   #222 (permalink)
Trader Rating: (37)
If you keep the stock line then there is no reason to take the fitting off the rail. You can try and see if Boomba will sell you the fitting they use in the their rails and use that to adapt to 6an by the fuel tank.
Old 06-16-2008, 05:27 PM   #223 (permalink)
i just did this.. do i take off the stock fuel line or no..? im replacing all of it with thick ss lines..!
Old 08-18-2008, 10:06 AM   #224 (permalink)
mpbiv's Avatar
Member Number: 42
I am currently in the middle of building one of these bottleneck fixes to go along with the return line setup I have pieced together.
I have read through this thread but there is still one thing that I am concerned with. For those who have split the fuel supply hose between the pump and the push-lok fitting, what hose did you end up using to fix the problem?
I've been looking through all the different hoses available in 5/16 size and I have not found anything really great. Is anyone using the SAE 30R9 rated hose?
'05 SRT-4: 366whp 388ft-lbs, 11.9@117mph
mpbiv is offline   Reply With Quote
Old 08-18-2008, 10:15 AM   #225 (permalink)
SkullingAxe's Avatar
Member Number: 39463
I am running the SS Braided Hose that i used for my return line. Its a -6 line so you will need to tighten the CRAP out of it on the pump itself. So far i havent had any issues from the line itself.
Bryan
2005 - Flame Red SRT-4 317hp/367tq
P.M. Me for details on installs, maintenance, and repair work in the North Georgia Area.
SkullingAxe is offline   Reply With Quote
