Old 06-08-2005, 05:42 PM   #1 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
Fuel system bottleneck fix, Feed line Mod
ALL THESE PARTS CAN BE FOUND AT
www.summitracing.com
www.jegs.com
for around 80-85 bucks maybe less
dont forget my free instructions at the bottom and ME online i can help you with anything if i have time just ask
Recently people have had some fuel problems. I had a problem getting enough fuel up top (higher RPMS) weather it was my pump or how I had done things I am not sure. What I do know is that the fix that was pointed out to me has helped my car in so many ways.
This removes the 1/8 feed bottle neck coming off the pump and using the stock filter, FPR when going to a return line
Drivability is better, tuning became much easier. And no more fuel problems
Below is a small picture of what was done
I am also going to try and include a parts list.
If you have any questions on what was done please feel free to ask
This is not 100% my original idea some of this info was taken from PSI FI, and a spool boy feed setup from neons.org
All I did was question the current setup and how I thought that it had to be a problem and needed help coming up with a solution
All prices are from summit
Parts list
1 -6 bulk head fitting
AER-FBM2072 $7.88
1 bulkhead fitting nut pack of 2
AER-FBM2100 $5.25
1 Stat-O-Seal, 9/ 16 in. I.D., Fit -6 AN, Aluminum with O-Ring, Pair
EAR-178009ERL $5.99
2 pushlock -6an fitting
AER-FBM1512 $4.95
3 feet of stainless braided hose -6
AER-FCA0603 $15.88
1 straight ends for the braided hose
AER-FBM1012 $5.95
1 90 ends for
AER-FBM4032 $16.88
Earls 85 micron 75psi Stainless Steel mesh element
EAR-230206ERL $31.39
2 packs of 4 5/16 fuel line clamps
2 feet of 5/16 fuel injection line
you will need a dremel tool
a drill
zip tie's
sanding drums for the dremel
and a little imagination
Vector is offline   Reply With Quote
Old 06-08-2005, 05:46 PM   #2 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
If you need more fuel then above continue forward off the filter with -6 to a boomba fuel rail or lorenzo fuel rail
if you need more fuel. then this you can do the pump rewire
if you need more fuel then this add an external walbro 255. this came from Ben @agp
if you need more then all of that you can add a inline areomotive 1000
Old 06-08-2005, 05:56 PM   #3 (permalink)
dasmopar's Avatar
Member Number: 6413
Trader Rating: (148)
Holy paint shop skillz Vector!!! Nice write up and good to see you sharing for once.
dasmopar is offline   Reply With Quote
Old 06-08-2005, 05:59 PM   #4 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
lol made paint skillZZZ i fixed something i forgot.
anyways this should get someone started atlest
Old 06-08-2005, 06:29 PM   #5 (permalink)
silverscooby's Avatar
Member Number: 1525
Awesome man. Let me ask you this, would this setup work with replacing the walbro I have in there already entirely with an aeromotive 1000? Will that aeromotive even fit in the stock location?
11.6@125
silverscooby is offline   Reply With Quote
Old 06-08-2005, 06:41 PM   #6 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
i dont think the aeromotive is a intank pump
you have 2 options
do this and use the walbro 255+ the aeromotive on the outside i think that will work. i would not do it without removing the bottleneck
or
get a pickup, and fab a bracket, point the pickup to the location of the factory pickup/sock. use the braket to hold the pickup in place do this mod to the outside of the tank where your 1000 pump will be
I would myself do this, and add a external walbro 255 inline. and do -6 to a rail off the rail -6 to aeromotive regulator -4 or -6 back to tank.
also get a boomba or lorenzo rail.
maybe even do the voltage rewire to both pumps
your running a crazy setup scooby. Ben said something about an intank and external combined should be like 800 hp worth of fuel.
Old 06-08-2005, 07:36 PM   #7 (permalink)
bpointer's Avatar
Member Number: 25998
So now the braided line to the rail is a good idea? I'm the man
bpointer is offline   Reply With Quote
Old 06-08-2005, 07:40 PM   #8 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
haha its only a good idea if you have the extra money or need it. but its not a must..
Old 06-08-2005, 08:38 PM   #9 (permalink)
RedSRT4Me's Avatar
Member Number: 402
Quote: Originally Posted by Vector
This is not 100% my original idea some of this info was taken from "spool boy feed setup from neons.org
As soon as I read the title I thought of Dennis before I read the thread. He was the 1st to my knowledge to get this mod working on the 2.4 turbo 1st gen
RedSRT4Me is offline   Reply With Quote
Old 06-08-2005, 08:41 PM   #10 (permalink)
RedSRT4Me's Avatar
Member Number: 402
I've got pics of Pablo's set-up running a SX1000 similar to the A1000.
Its actually not much more involved than the diagram Vector has provided.
Old 06-08-2005, 08:43 PM   #11 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
I only know him or it as a spoolboy setup. its great info but was just sitting over on neons.org gathering dust.
This is a collection of his info, psi fi and mine and ben@agp
I myself really like how well the car works now. when i removed the stock FPR i about shit when i saw the size of the hole i was trying to feed my motor with fuel through
Old 06-08-2005, 08:49 PM   #12 (permalink)
jdp
jdp's Avatar
Member Number: 14931
Ha... if you wanna get technical I said go 3/8ths aluminum hardline from the filter to the engine bay... lighter and safer in one package
But yeah I am glad the hour I spent finding the parts that were needed helped out!
jdp is offline   Reply With Quote
Old 06-08-2005, 08:57 PM   #13 (permalink)
RedSRT4Me's Avatar
Member Number: 402
Vector are you removing the stock filter/reg completely?
If you are how are you getting the bulk head to seal properly? Did you take any pics of the tank lid?
I was just going to drill another hole like I did for the return for the external pump.
Old 06-08-2005, 09:06 PM   #14 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
I filled the stock filter /reg with JB water weld and put a cap on it its just a plug
i drilled a hole as close to inline with the top of the pump as i could. much like you would if you did a return to this location
no i never seem to ahve a camera around when i need to take pics
Old 06-08-2005, 09:07 PM   #15 (permalink)
dsmlights's Avatar
Member Number: 1186
Trader Rating: (13)
nice nice this is the way to do it this is defenately a fix blacksrt4u has this same setup but with another fuel pump external and he has 650cc and he has enough fuel for 500 whp and 580 on spray soo, defenately that stock fpr is wa causing issue i think. well soon i will get my gt40kit with my 750cc and lets see how much boost i can run before i run out of fuel too lol
--------Dyno#s update 4/01/05--------
stock turbo spike 21 psi and drop to 15 to red line
307 whp/370 wtq
-----------Dont remerber the date --------------
last dyno i will spray on stock turbo
410 whp/435 wtq Now its running harder
---------------Bigger turbo in 24psi--------------
ran like a champ for 2 days then the motor messed up, now debating wa to get any suggestions
not bad for S0 car right :0
dsmlights is offline   Reply With Quote
