Old 09-26-2007, 08:21 AM   #16 (permalink)
cali's Avatar
Member Number: 159
Please expand on how DCX limits the voltage to the pump?
How are they controlling the voltage to the pump?
Does this kit bypass the ASD system?
someone is watching me
Old 09-26-2007, 09:18 AM   #17 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (61)
Quote: Originally Posted by ptperformance
Quote: Originally Posted by Canuck_2k
I would say it's prolly good for those who is not running a returnline. Otherwise if you have a returnline, this mod is prolly not needed.
Still needed no matter what. Return line or not the fuel pump will still like the additional voltage. It will only make the pump run that much better.
Hmm..
did anybody in your crew test out w/ a return line?
SCT Tuned by Kevin@AGP Turbo
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 09-26-2007, 12:34 PM   #18 (permalink)
apexanimal's Avatar
Member Number: 41793
will this work for a ptgt? like me?!
Do it once - Do it right.
'03 GT 5spd: Stage 1+
The PTGT Webpage!!
apexanimal is online now   Reply With Quote
Old 09-26-2007, 02:54 PM   #19 (permalink)
Member Number: 25021
Painless makes a fuel pump relay kit... Weather proof #30131 $43.99 Standard #50102 $29.99... I know these are universal vs yours. What makes your kit so special that you charge 90 bucks for it? Not trying to be an ass, but that's huge difference. I understand that yours is "plug and play"... With the painless kit you might have to do a little work.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Old 09-26-2007, 03:49 PM   #20 (permalink)
tavenger5's Avatar
Member Number: 42245
Trader Rating: (23)
This is explained in the first post...
| CBB Turbonetics 50 Trim | AEM EMS | Cooling Mist WI | Kenetic TB |
| Ported Intake | Werks S2 | SB Stage 5x | Stage 2 Crower Cams | Carputer
| S3 Coilovers + Sways + Traction Bars | Pics
Black 1998 Avenger ES w/ 3.0L swap Pics
Cell Phone Forums | Car Dealer Forums
tavenger5 is offline   Reply With Quote
Old 09-27-2007, 10:01 AM   #21 (permalink)
daniel427ss's Avatar
Member Number: 51325
hmmm.....
daniel427ss is offline   Reply With Quote
Old 09-27-2007, 10:20 AM   #22 (permalink)
I don't think it's worth the extra money... That's way to much money. I read the first post.
Old 09-27-2007, 11:43 AM   #23 (permalink)
apexanimal's Avatar
hmmm.....
x3
and double checking again - does it work for ptgts?
Old 09-27-2007, 05:34 PM   #24 (permalink)
cali's Avatar
Member Number: 159
no answer..huh...
Old 09-27-2007, 05:41 PM   #25 (permalink)
Member Number: 44190
DCX doesn't limit it intentonally, but it gets limited because of the wire size and temperature involved in the engine bay, causing a drop in voltage above
4k rpms. Others have used the one in the how-to section adn it works great but if you want PNP then this is the shiznit!!!
blksmrf92 is offline   Reply With Quote
Old 09-27-2007, 07:59 PM   #26 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (552)
Yes it passes the ADS systems but it still uses the signal from the ADS to drive the relay. I do not feel that DCX limited the voltage intentionaly its just a by product of cheap wire and making use of what they had on hand. Its not controlled it just something that happens. If you don't believe me check it for yourself, 10.x volts at idle seems to be the common place for them and anything above 4800 and WOT you see an even greater drop in voltage.
Old 09-27-2007, 08:05 PM   #27 (permalink)
Hmm..
Our stage 3 SST tester did one with his set up. He very much said it was worth it.
Old 09-27-2007, 08:07 PM   #28 (permalink)
cali's Avatar
Member Number: 159
I will check...I never paid attn to these fuel pump threads...but I will look at a wiring diagram.
This wire has to be real small to produce such a V drop. You guys sure its not a 'current' issue due to poor grounds?
Old 09-27-2007, 08:24 PM   #29 (permalink)
16/18 gauge is what I have found.
Yes, we have installed grounding kits and they have done nothing to increase the voltage to the pump. The stock wire is over 12 feet long and makes 4 different connections before it even hit the main pump wire.
Old 09-27-2007, 08:53 PM   #30 (permalink)
apexanimal's Avatar
so will it work for ptgts?
» Search Used Cars
