Old 08-09-2007, 09:30 PM   #1 (permalink)
sneaky brian's Avatar
Member Number: 21602
Trader Rating: (26)
Default Fuel pressure and flow conversion excell sheet
i made up and excel sheet that allows you to input a new fuel pressure and it will tell you what the injectors will flow with that new pressure. also it allows you to input a desired fuel flow and it will output what fuel pressure you will need to run to attain that fuel flow.
http://personal.ecu.edu/hrb0312/fuelconversion.xls
PTP SST and PNP exhaust manifold, PTP 3" O2 housing, CTI 3" SEE, PTP FTM and stage 2 injectors, red star fuel return line, perrin fuel rail, and 255 fuel pump w/ re-wire mod, AGP WGA, w/ AVC-R EBC @21lbs, DCR top end mod, Stage 1 PCM, QuickWhips BFMIC, injen SRI, Bwoody H-brace and traction bars.
sneaky brian is offline   Reply With Quote
Old 08-09-2007, 09:33 PM   #2 (permalink)
tinctorus's Avatar
Member Number: 30504
Trader Rating: (42)
Wow thats pretty cool man
this needs to be stickied so people can use this when they need to
Quote: Originally Posted by Tex
india not arab. think himiny-bimminy not alalalalalalala
tinctorus is offline   Reply With Quote
Old 08-10-2007, 06:04 AM   #3 (permalink)
Super Moderator
1badsrt-4's Avatar
Member Number: 21276
Trader Rating: (53)
Nice job man thata rather helpful
11.34 @ 128.33 mph. Stock motor, head, cams and ecu
1badsrt-4 is offline   Reply With Quote
Old 07-21-2008, 11:58 AM   #4 (permalink)
smoothasdee's Avatar
Member Number: 60902
is this witha fuel return line also?
smoothasdee is offline   Reply With Quote
Old 07-22-2008, 07:56 PM   #5 (permalink)
Trader Rating: (26)
i made it for that use pretty much. so if you have stage 1's or 2's for example you can use the excel sheet to see what fuel pressure you would need to set the regulator to run what a set of 650 or 750cc's would run.
Page generated in 0.20218 seconds with 11 queries
