Old 07-17-2008, 05:50 PM   #1 (permalink)
Buy/Sell Section Nazi
Member Number: 58545
Trader Rating: (19)
Default FPR gauge
ok my old FPR gauge on my return line was leaking its fluid so i changed it out but now its not reading............
the old gauge was 0-100 and this one is a 0-60, any idea why?
also i just changed from a perrin fuel rail to an 03 fuel rail w/shrader valve
All items for sale will use the following format & MUST include pictures:
Name: (FIRST & LAST)
Contact: (VALID EMAIL OR PHONE #)
Price:
Description:
If you have any questions please see here:
http://www.srtforums.com/forums/f27/...elines-352468/
johnnybsrt is offline   Reply With Quote
Old 07-17-2008, 06:04 PM   #2 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Trader Rating: (21)
Did you take the valve out of the 03 rail? Kind of a stupid question, but I've seen it done before so I figured I'd ask. Some gauges are different, some read 100psi, 140psi, there's tons of diffrent ones out there. You'll definitey need to find one thats going to read higher than 60 though as you'll go above that from time to time when tuning your fuel and whatnot.
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is online now   Reply With Quote
Old 07-17-2008, 06:07 PM   #3 (permalink)
Trader Rating: (19)
uhhhhhhhh theres a valve in the rail? yeah not such a stupid question hahaha
is it like a pin head?
i figured the 0-60 was fine?
im running the AGP 50 trim setup
Old 07-17-2008, 07:48 PM   #4 (permalink)
Trader Rating: (19)
im really not sure what valve you are speaking of
Old 07-18-2008, 02:47 AM   #5 (permalink)
Trader Rating: (21)
Ok...inside the schrader valve looks just like a valve stem on a tire. You push the little button/pin and it relieves the pressure so you can pull your fuel rail off/remove injectors/etc. It comes out just like a schrader valve on a tire does. You'll need to get either a really small straightblade screwdriver and unscrew it from one side, or go pick up one of those little schrader valve remover tools. It's the one on the small screwdrivers that have the metal cylinder on the end with a notch in it. Run by a tire shop and they might even have a spare floating around they could give you or you can probably buy those things for pennies on the dollar.
That valve has to come out in order for fuel to flow through it.
If you are using a rising rate setup (meaning your fuel pressure rises when your boost rises) then you will surely go past 60 psi. If you're not looking to go any higher than 60 then you SHOULD be alright with that gauge.
Old 07-18-2008, 05:10 AM   #6 (permalink)
Trader Rating: (19)
Ah thanks. I'm just going to take your advice and get the 0-100, its only 20 bucks anyway
Page generated in 0.14663 seconds with 11 queries
