Flow Tested 888cc/1025cc injectors, and the results are? - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-16-2013, 07:36 PM   #16 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
Where did you originally get these from?
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 01-16-2013, 07:40 PM   #17 (permalink)
SRTotM Moderator
Bad98rt's Avatar
Member Number: 78946
I believe AGP
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things
MAP EF4 stock block, stock head
452whp on EMS at 26 psi
100&92 octane mix
Fully built long block and big numbers coming!
Bad98rt is offline   Reply With Quote
Old 01-16-2013, 07:41 PM   #18 (permalink)
Millernz123's Avatar
Member Number: 60887
I originally got them through AGP
http://www.indianasrt.com/
Built motor by Kriegspeed
Millernz123 is offline   Reply With Quote
Old 01-16-2013, 08:22 PM   #19 (permalink)
They were cleaned and tested if you would like to call them and verify that then do so. I wouldn't put this up on the national forum and I wouldnt have just sent my injectors in to be tested and not have them cleaned and pay the money out. My engine builder Chris Krieg very reputable builder atleast in Indiana with srt's knows the guy pretty well and talked to him Direct about the injectors by all means you can contact him also, if you also noticed on the sheet that there were also parts replaced. If infact if there was a difference before and after cleaning that is when they would list it on the sheet next to the comments.
Old 01-16-2013, 08:29 PM   #20 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
I'm done. I'm deleting All my posts. Enjoy a car that some one else built. Lol.
Oh FYI u get new seals on just a flow test too. Also u get a before and after. I dont see before. See below.
http://fuelinjectorclinic.com/fuel-injector-cleaning
Old 01-16-2013, 08:34 PM   #21 (permalink)
SRTotM Moderator
Bad98rt's Avatar
What is your issue? Just because FIC filled out your sheet one way does not mean they have to fill it out that way every single time or its wrong.. The sheet is from FIC so what it's not filled out to or standards
100&92 octane mix
Old 01-16-2013, 08:44 PM   #22 (permalink)
SRT of the Month
I'm trying to let the guy know what's up.
He's sure they were cleaned that's fine I'm gonna stop posting. I'm not gonna help some one that won't help himself.
Facts are fact.
Flow data sheet: You will receive a flow sheet which contains flow data from the initial test as well as the post-cleaning test. It is always interesting to see the comparison between used, dirty fuel injectors and nice clean units! See the
^^ from fic.
Hmm don't see a before and after. Just a flow rate.
Fact 1
I got 4 injectors tested one was low. I told them to clean all 4 on the paper work I sent. Fic called me and said only one needed cleaning they will re flow test it if it comes back higher than the other 3 they would clean all 4. After retest they all flowed the same. My sheet reflect one getting cleaned.
Fact 2
His sheet don't show a before and after. And fic states they will put it on the sheet if done.
Which tells me it was just a flow test.
Old 01-16-2013, 08:47 PM   #23 (permalink)
SRTotM Moderator
Bad98rt's Avatar
Facts are fact.
^^ from fic.
Yes but there is always a circumstance that they could not test it before... Things happen and sometimes they skip steps it happens I know it does...
So when he posts a invoice of these said injectors that says they were cleaned then what happens from there
100&92 octane mix
Old 01-16-2013, 08:48 PM   #24 (permalink)
This exactly, and so what if my motor is built by someone else he is a professional at what he does.
Old 01-16-2013, 08:52 PM   #25 (permalink)
SRT of the Month
Show me on the invoice where it said it was cleaned
He posted his flow sheet. Not invoice.
I'm just stating all the obvious things. Take it or leave it.
Old 01-16-2013, 08:54 PM   #26 (permalink)
SRTotM Moderator
Bad98rt's Avatar
The invoice will be posted soon enough and when it is... It will be time for you to tuck your tail between your legs
100&92 octane mix
Old 01-16-2013, 09:12 PM   #27 (permalink)
ziggo0's Avatar
Member Number: 63759
It almost seems like everything is a conspiracy on this forum lol.
Stone White 05 - Stock Head & Bottom End - Holset HX35 7 Blade - e85 & many other supporting mods.
Old 01-16-2013, 09:16 PM   #28 (permalink)
D-SRT's Avatar
Member Number: 80561
You ever think that maybe they were flowed with a different substance from the manufacturer than what yours were subjected to in the latest flow test?
You do realize, FIC 1100's and ID 1000's are IDENTICAL injectors...and FIC 2150's and ID 2000's are IDENTICAL injectors, right? FIC uses a different liquid and pretty much artificially boosts their numbers, though they are the same injector.
This has nothing to do with your particular case, but it's a prime example which is what you could may be experiencing.
Maybe it was tested with the same liquid as what Seimens rated theirs as. Maybe not. Just stating the obvious that many seemed to miss.
Pumpking.
10.71@140. 1st SRT in TENS in CA.
Thanks to:
TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/
GOKEY RACING for anything fabrication related
instagram for updates and pics: m_santiago37
D-SRT is online now   Reply With Quote
Old 01-16-2013, 09:16 PM   #29 (permalink)
SRT of the Month
Me tuck my tail haha u funny.
I'm just giving advice. I hope they were cleaned.
Old 01-16-2013, 09:18 PM   #30 (permalink)
mole''s Avatar
Member Number: 17477
Facts are fact.
^^ from fic.
Fact 1
Fact 2
Never had a set cleaned/flowed by FIC before but had a few sets done by RC (local to me) and they did it the same way as Brandon has described.
It does look just like a flow test to me.
DCR spiced and Tuned by the Mad Scientist team
Jay@N2MB and Nigel@BST (turbo666)
Mole' (STOCK TURBO) 16g BWS setup #s
380hp+ and 444tq+
11.7@122
1.71 60ft
PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com .
