e85 back to pump - Dodge SRT Forum
post #1 of 13 (permalink) Old 01-30-2014, 06:14 PM Thread Starter
DMW
DMW's Avatar
Quoted: 34 Post(s)
e85 back to pump
I've been on straight e85 for about 3 months now. I decided to switch back to pump gas, but my tank was just under 1/4 tank when I switched back. I reset the battery and loaded my pump gas tune back in.
Now I am getting very bad hesitation between 2k and 3k rpm. After that it seems to rev fine, but the air/fuel is on the lean side. I added WOT FUEL on my DSP, and it's about right now.
My question is could the 1/4 tank of e85 left in my tank be causing my hesitation problem?
-Dave '05 SRT-4
Stage 3 on e85 = 380/407 whp/tq | 11.96 @ 124
DMW is offline
post #2 of 13 (permalink) Old 01-30-2014, 06:36 PM
SRT of the Month
NachO_SRT's Avatar
Quoted: 13 Post(s)
Got some data logs? Better to use those than have us just guess at it.
Why wouldn't you just drain the E85 completely?
DD - 2015 3500 Denali Duramax 500hp 1100ft/lbs
Track Car - 2004 E-blue; Mods and pics: CLICK
S259@ 25psi:614/567 -6/10, E85 - Meanblueberry.
Aug 2010 SRT of the Month
NachO_SRT is offline
post #3 of 13 (permalink) Old 01-31-2014, 10:40 AM
ACR_Joe's Avatar
Quoted: 0 Post(s)
Is there a easy way to do this? ^
Mods: Duster E85 Tune, AEM Wideband, AEM SRI, PTP 55mm TB, Magnecore Wires, Catch Can, Check Valve, 3" Catless DP, Hawk HPS pads, NGK Iridium plugs, Mopar STS, Booger Bushings, Prothane MM Inserts, BC Coilovers, Prothane LCA bushings, DC Sports Strut Braces (F & R), Hankook RS3s & Rocking the ACR/BBS wheels again!!.
ACR_Joe is offline
post #4 of 13 (permalink) Old 01-31-2014, 11:38 AM
Quoted: 5 Post(s)
Jump the fuel pump relay, undo the fuel line at the rail...
squarebit is offline
post #5 of 13 (permalink) Old 01-31-2014, 12:41 PM
ACR_Joe's Avatar
Quoted: 0 Post(s)
Cool, does this run the risk of overheating the pump?
ACR_Joe is offline
post #6 of 13 (permalink) Old 01-31-2014, 01:36 PM
SRT of the Month
NachO_SRT's Avatar
Quoted: 13 Post(s)
Not when it has fuel to pump - if you leave it and it runs without fuel, yes. Otherwise, if your prudent, and pay attention, no, it's fine.
post #7 of 13 (permalink) Old 01-31-2014, 02:11 PM Thread Starter
DMW
DMW's Avatar
Quoted: 34 Post(s)
My problem is, what do I do with the fuel once I drain it? I plan to go out an drain 5 gallons here shortly. I wish I owned another car that was flex fuel.
-Dave '05 SRT-4
DMW is offline
post #8 of 13 (permalink) Old 02-08-2014, 07:46 PM
SRT of the Month
NachO_SRT's Avatar
Quoted: 13 Post(s)
I mix it with my lawn mower gas =-) no more than 50/50
post #9 of 13 (permalink) Old 02-08-2014, 08:40 PM
duster360's Avatar
Quoted: 138 Post(s)
Yes that's 100% the problem.
The 1/4 tank of E85 has shifted the stoichiometric ratio enough to jack with the fuel trims.
Its not a big deal besides being annoying and given enough time the Fuel Trims will fix the hesitation and for certain the issue will be gone once you fill up again.
Personally I'd just avoid WOT and just run the tank out.
WWW.NEEDLESSTORQUE.COM
1025ccInj+ E85/GAS Base tunes =$385
E85+Gas Base tune Combo $150!!
Please EMAIL!!! dave at needlesstorque.com
www.facebook.com/needlesstorque
duster360 is offline
post #10 of 13 (permalink) Old 02-19-2014, 08:26 AM
Quoted: 0 Post(s)
Took the words right out of my mouth.
SP33D FREAK is offline
post #11 of 13 (permalink) Old 02-20-2014, 02:02 PM Thread Starter
DMW
DMW's Avatar
Quoted: 34 Post(s)
This was resolved after a couple more tanks of regular 91.
Now I have just have the tiny hesitation at 2k rpm because of the AGP RL. I have the parts on the bench to convert it to after the rail so hopefully everything will be right once this is done.
-Dave '05 SRT-4
DMW is offline
post #12 of 13 (permalink) Old 02-24-2014, 07:01 AM Thread Starter
DMW
DMW's Avatar
Quoted: 34 Post(s)
I converted the fpr to be after the rail and now she drives like stock again. No hesitation whatsoever.
Sent from
Click image for larger version
-Dave '05 SRT-4
DMW is offline
post #13 of 13 (permalink) Old 02-24-2014, 09:28 AM
Quoted: 0 Post(s)
^^ ohh Shiny!
2004 Black Srt4 -
OLD setup - 11.6 @ 125mph with a 1.8 60' 5500' DA - S3 Stock longblock
Current setup:
E85, 56mm, Ported 1+2+, Built & Strapped....
dabezt1 is offline
User Tag List
Linear Mode Linear Mode
