Old 05-29-2009, 11:12 PM   #1 (permalink)
ST3PH3N'S SRT-4's Avatar
Member Number: 57024
Default e85 > 725cc inj
Well today was my first day with straight e85.........
setup:
60 trim
Perrin Fuel Rail
RealTune 725cc injectors
Fuel Return (steel braided line)
Fuel pressure regulator @ 60psi
Walbro 255 lph fuel pump
started off @ 20 lbs off boost 13.0 to redline
then 18 lbs, 12.8 to redline
16 lbs, 12.6 to redline
14 lbs 12.5 to redline
10 lbs 13.0 lol wg didnt even open
was trying to think of new fuel setup to fit my needs of 550-600whp range, any advise?
was thinking about going with a bigger inline external pump fed by walbro 255 but not sure. Maybe even just a Aeromotive A1000 Fuel Pumps and thats it...And inj size, no clue.
thanks
stephen
Stop messing around with vendors who dont care, Shop PTP and be treated like family.
ST3PH3N'S SRT-4 is offline   Reply With Quote
Old 05-29-2009, 11:15 PM   #2 (permalink)
Member Number: 30696
with 900's im almost out of fuel at 27PSI on a 50trim
amdguy is offline   Reply With Quote
Old 05-29-2009, 11:17 PM   #3 (permalink)
100% e85?
whats ur fuel pressure @?
Old 05-29-2009, 11:18 PM   #4 (permalink)
Quote: Originally Posted by ST3PH3N'S SRT-4 View Post
100% e85?
FP is at 48 PSI
100% E-85 all day every day
Old 05-29-2009, 11:21 PM   #5 (permalink)
FP is at 48 PSI
meth inj? fuel pump?
725 @ 60 psi should be flowin in the 800 range, dont see why i cant be atleast 15lbs of boost...
Old 05-29-2009, 11:27 PM   #6 (permalink)
im closer to the 1000 range at the FP im at then the 900's range.
bottle neck fix?
i have -6 to the rail, and a inline booster pump to keep volume above 300lph till after 65 PSI
a normal walbro 255 is only flowing ~200 - 225 lph @ 60psi, then if its 1:1, at 75 psi its only flowing 180-200LPH (depends on voltage, and room for error)
Old 05-29-2009, 11:31 PM   #7 (permalink)
bottle neck fix?
what inline pump? hows it workin for u? ill ask about bottle neck fix, bought car wth fuel system in it.
Old 05-29-2009, 11:34 PM   #8 (permalink)
if i was to do it again, i would do 2 intank pumps, the inline pump has caused a few problems, its a inline walbro 255
Old 05-29-2009, 11:36 PM   #9 (permalink)
awesome, thnx 4 ur info
Old 05-29-2009, 11:37 PM   #10 (permalink)
ir you want any more info, there is a pretty long thread in the fuel section on it
Old 05-30-2009, 12:06 AM   #11 (permalink)
awesome, which one? ill prolly end up going dual parallel pumps or 1 inline Aeromotive A1000
Old 05-30-2009, 06:49 PM   #12 (permalink)
19 psi's Avatar
Member Number: 12457
uuh hey amdguy what are your A/F's on those 900's if you dont mind?
mzods:
S3r tial wheel AGP S3 WGA 30psi
bosch 1000cc inj. E85 (HOM everywhere)
KW V2 coilovers
Boomba mounts
CM S3
E46 bi-projector full retro'd headlights
+ every other bolt on
19 psi is offline   Reply With Quote
Old 05-30-2009, 06:57 PM   #13 (permalink)
today at the dyno, at ~50psi fuel pressure, 25 PSI, it was ~12.5 at redline
Old 05-30-2009, 07:11 PM   #14 (permalink)
19 psi's Avatar
today huh....so uhhh what numbers did you get...lol
also... do you notice with those 900's is it rich at first at all and then get to 12.5, or is it pretty much lean the whole time?
mzods:
KW V2 coilovers
Boomba mounts
CM S3
Old 05-30-2009, 08:04 PM   #15 (permalink)
still working on the tune, its to the same point i was last year with 110 in it, with 1 PSI less.
it was pig rich in the mid range (3k till 4.5k), so my spool was killed. i ended up with 417whp
this is a car with a stock head, stock Thorttle body, and very little timing. advanced the timing a bit, and leaned her out in the middle and she felt ALOT stronger
