Old 02-01-2008, 06:21 PM   #1 (permalink)
Member Number: 18856
Default E-85
put this stuff in the other day. figured i try to see if i could use mt 750's no worky looks like i'll be investing in a new pump and 1000 cc. ran great until i decided to turn up the boost. o well for now i'll keep it under 18 pounds till the new stuff arrives.
not a thing just another slow ass neon
joe smalls is offline   Reply With Quote
Old 02-03-2008, 02:11 AM   #2 (permalink)
SlowSilvr05's Avatar
Member Number: 59686
Trader Rating: (17)
i heard that on e85 you have to get injectors that flow 30% more than what you normally would and a bigger pump of course.
SlowSilvr05 is offline   Reply With Quote
Old 02-03-2008, 02:45 PM   #3 (permalink)
Member Number: 53402
Our cars are only meant for the good stuff! you are taking a big chance on spark Knock since it wont clean the carbon in the combustion chamber like Premium would. that will cause Early detination (premature) makes the knock sound or metallic ping. since the carbon is already heated in the chamber when the fuel is let in it ignites robbing the performance of the car. not something i would want to do.
orangesrt-4 is offline   Reply With Quote
Old 02-05-2008, 10:37 PM   #4 (permalink)
Member Number: 30819
Trader Rating: (12)
e-85 has MUCH more octane than the "good stuff" i believe you're referring to.. just not as much energy, hence the need for more fuel
OP give us an update on how e-85 runs in your car after a while in relation to wear, erosion of factory parts, etc. thanks!
12.29 @ 110.75 1.67 60' on slicks
stock turbo on stage 0
summy is offline   Reply With Quote
Old 02-08-2008, 10:37 AM   #5 (permalink)
Ok Please tell me why E-85 is located at the end where the LOW GRADE fuel is at. E = Economy 85= 85 octane, so tell me how this is higher then 93-93 octane???
Also if you run E-85 in a car that is not equipt to handle it then you will do damage to the engine, fuel cell, Pump, filter. OR make it run like crap.
Old 02-08-2008, 11:04 AM   #6 (permalink)
Member Number: 31909
Maybe you should read up on the subject a little before you make a stupid post that shows you know nothing about E-85.
E = Ethanol (a form of alcohol) 85= 85% ethanol, 15% gasoline
I believe E-85 has an octane rating of ~100
ThirtyTwo is offline   Reply With Quote
Old 02-08-2008, 01:04 PM   #7 (permalink)
Nasty_NAS's Avatar
Member Number: 11197
lol wow dude read a book.. ever think that they put it there cause it isn't like reg gas?? sorta like disel
Agp dbb 50, Agp race fmic, Agp lhp, Dtec,
rc 750s, Crane fire wires, screamin demon coil,
jmb uhp & 3" cai, Tial bov, Twm sts w/stainless knob, DC strut tower bar, Injen turboback
Lca Bushings w/ Rage Delrine, Cooling Mist stage 2
Inovative wideband w/xd-16 guage, Greddy TT
Stewart Warner guages (Boost, EGT & Oil Pressure)
Blue guages w/red line, Megan coilovers, Dcr Bottom end, dcr head comming soon
Nasty_NAS is offline   Reply With Quote
Old 02-08-2008, 01:16 PM   #8 (permalink)
rubicon04's Avatar
Member Number: 26253
85= ^^^ percenatge of denatured methanol usually between 100 -105 octane from what ive seen
04 black stock turbo- r.i.p
05 white 60 trim -407hp and 398ftlbs at 22 psi- sold
rubicon04 is offline   Reply With Quote
Old 02-08-2008, 01:18 PM   #9 (permalink)
haha it's like putting in the cheapest fuel you can buy. yes you will have bad gas mileage, rough idle and can destory your engine. how about you run it for about a year in your car without changing anything and see how will this will hold up! Yes it might be higher Octane but performance wise it's not there.
Old 02-08-2008, 01:20 PM   #10 (permalink)
Ok so tell me if you use Race gas 100+ or E85 yourtelling me that performance wise it will be the same???? NOT GOING TO HAPPEN
OUR cars are only able to handle 10% alcohol how about you do more research.
Old 02-08-2008, 01:32 PM   #11 (permalink)
rubicon04's Avatar
did i say it performed better, no i did not. If properly set up then yes you can have a more aggressive tune because of the higher resistance against knock, me do more research all i stated were facts. what you stated was completely false and pretty much ignorant being that you thought you were right E-85 does not stand for economy 85 octane dumbass
Old 02-08-2008, 01:36 PM   #12 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (58)
note to self, dont argue when you dont know what your talking about
thats fantastic
AGP S256 + B&G FLASH
Old 02-08-2008, 04:39 PM   #13 (permalink)
Edgehold's Avatar
Member Number: 55411
I thought that you had to change all of your fuel system out because E-85 is corrosive. Saw a thing on changing engines for cheaper gas on the speed channel. Not sure, just wondering.
Edgehold is offline   Reply With Quote
Old 02-08-2008, 08:01 PM   #14 (permalink)
Its not methanol either, its ethanol; methanol would be M-85. And ethanol is somewhat corrosive but not as much as many make it out to be. You could probably make more power on E-85 than on 93 pump or even 100 race gas.
Old 02-09-2008, 08:19 AM   #15 (permalink)
Thank you, I agree with you on this. Now Our cars are only set up to handle 10% ethanol (alcohol) you would have to change the fuel system to handle more. and ethanol isn't corrosive it actually cleans the fuel lines and injectors aren't suppose to gum up like regular gasoline.
Page generated in 0.31201 seconds with 11 queries
Search Engine Optimization by
