Old 01-12-2005, 12:09 AM   #61 (permalink)
dangerously_cool's Avatar
Member Number: 1577
Quote: Originally Posted by dognutz
thank you for posting.. you were useing STD and 1.02 correction is that right.
Oh yea...hey looks like it. Reading > me.
Edit: Just read you're sans map clamp on that run. Like most of them probably said, there be your problem.
Fuel pump could be it too...the shop that did mine, instead of putting in the regular with the piece of metal blocking it so pressure is adjustable, didn't touch it. I found this out only months after having to have the E-01 and emanage completely rewired.
Gone to those big twisties in the sky.
dangerously_cool is offline   Reply With Quote
Old 01-12-2005, 04:14 AM   #62 (permalink)
dognutz's Avatar
Member Number: 14819
Trader Rating: (15)
okay so you think it could be that thay maybe never put in the alum piece on the stock regulator i will have to check this out.. this week i will drop the tank does anyone know the number of stock pump.. snd the walbor 255 pump..
HOME OF THE MOST HP SRT4 ON NO SPRAY!! WITH 31psi BOOST
FOR ALL YOUR NEEDS RAGE-TEK IS THE ANSWER
Shop (954) 978-0978
Cell (954) 274-4175
http://mike-castaldo.tripod.com/
also check herehttp://home.comcast.net/~extreme1neo...ome.html-.html
dognutz is offline   Reply With Quote
Old 01-12-2005, 07:23 AM   #63 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
ok... first there is not enough octane for 27psi (95 octane)..
Second (after running atleast 104 octane) you need to be pulling atleast -25% on the safc from 3500 to redline for 27psi.. remember this is a 3 bar map. The stock pcm maxs out the pulse width at 89% at 18psi. It pulls lots of timing to try and reduce boost over 18 psi. You will have the same fuel being put into the engine at -10/-15/-20 and -25% at 27psi.. With the rising rate regulator set at 50psi vac line off you will have 70 psi at 20psi boost and 77psi at 27psi boost.
Rules:
Pcm must not see more than 18psi.. set the boost to 18 psi get a map input voltage reading on the sensor screen of the safc. Then turn the boost up and the % down so that the safc map output is never above that original 18 psi number.
Never run more than 22-23psi on 93 octane on a stock pcm .. you can but you will see spark retard due to knock.. whenever you see dips in the power band it is usally due to knock induced spark retard. when you see rapid dips and spikes thats detonation.
Always run enough octane plus 2 points..
buy a scan tool to montior knock.
Nemo
RAGE Technologies The Vendor that Knows!!
954-915-0016 954-274-4175
1st Turbo Neon 1st 2.4L Neon 1st 2.6l stroker 01' 1st all motor 12's, 11's, 11.06/124
1st neon 13's, 12's 12.72/112 in 96
714whp 10.51@131.73 3150lbs w cage/driver
Best MPH 138 02/07
NemoFoss is offline   Reply With Quote
Old 01-12-2005, 03:20 PM   #64 (permalink)
dognutz's Avatar
Trader Rating: (15)
okay guys found the problem with the help of nemo over the phone.. i have a tune and my fuel persure problem fixed.. i am hitting 27 psi with this tune and in 4th gear i get massaive amount of tq steer.. this car is will over 400 hp butt dyno.. i can't beleive i did a dyno run on the phone..i know i just picked up another 70 to 100 hp.. yep believe it guys dyno over the phone.. NEMO kicks ASS... and the 50 trim is now flying and i can't stress enough AGP 50trim rock.. thanks to all the guys that helped me on this.. thanks and hope yall's car is doing as will as mine is now.. oo 2 more words.. GOD DAMN.. nemo AGP for makeing a nice kit..
Old 01-12-2005, 03:36 PM   #65 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
can you tell us what you did to fix it? ..what you might have had wrong or what was wrong
whats the wide band telling you just want to make sure your not lean now
thanks for the updates
Vector is offline   Reply With Quote
Old 01-12-2005, 03:44 PM   #66 (permalink)
dognutz's Avatar
Trader Rating: (15)
fuel persure gauge was broken.. when i took it off it was reading 10 psi.. when it should be 0.. replace it with a new one.. and readjust tune per nemo specs.. and now 11.8 at redline.. the car is will over 450hp i know it.. settings as it stands right now..
vac off 50
vac on 38
1000/3800-20%
4200-19%
4800-21%
5400-21%
5800-21%
6200-21%
Old 01-12-2005, 04:08 PM   #67 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
vac off 50
vac on 38
1000/3800-20%
4200-19%
4800-21%
5400-21%
5800-21%
6200-21%
nice work that blows about the FP gauge something so simple making so many problems
whens the new dyno?
Old 01-12-2005, 04:29 PM   #68 (permalink)
dognutz's Avatar
Trader Rating: (15)
whens the new dyno?
22nd i will try and get another one before then if i can.. thanks again vector and all that help.. youll rock too..
Old 01-12-2005, 04:44 PM   #69 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
hey no problem.... i was just throwing out ideas things to try/trouble shoot
i knows its a bitch when you think you have everything and get a big stick in your spokes
its good that everyone comes on here willing to ask... hey did you try this or it could be that
you would be forever doing it on your own
Old 01-12-2005, 04:51 PM   #70 (permalink)
Steven Burgess's Avatar
Member Number: 1515
Glad you found the problem Mike. I had that "fuzzy" fealing it was the guage!!!
Steve B.
Custom 60-1 turbo
434hp 419torque @ 25psi
7.7@95mph
Stock turbo, 295whp @ 21psi 7.9@88.8mph
Local Sponsor: www.4totalperformance.com
Steven Burgess is offline   Reply With Quote
Old 01-12-2005, 04:55 PM   #71 (permalink)
Member Number: 1577
Glad to hear you found the problem. It really is hard to find when you think everything's right. I had this happen to me with several different things after I had the E-01 installed. Took over six months to fix.
Congrats.
Old 01-12-2005, 06:20 PM   #72 (permalink)
dognutz's Avatar
Trader Rating: (15)
thanks again and srt4 forums is the shit.. i can't beleive i got as much help as i did and everyone was so damn smart.. youll perity much knew it was somthing with the fuel.. youll pointed me in the right direction.. keep up the good work guys.. hope this post helps others out there..
Old 01-12-2005, 06:32 PM   #73 (permalink)
SRToc Member
metfan2000_99's Avatar
Member Number: 2980
Awesome Mike!! I cant wait to get my car going!! Sweet!!!!
List of mods:
AGP T3/t04 50 trim
AGP FMIC
AGP CAI
AGP Fuel kit (SAFC-2)
AGP Hard Pipe
Return Fuel Line
HKS SSQ BOV
Motor Mounts
metfan2000_99 is offline   Reply With Quote
Old 01-12-2005, 06:37 PM   #74 (permalink)
dognutz's Avatar
Trader Rating: (15)
when you going to agp.. r you still fooling plugs..
Old 01-12-2005, 06:41 PM   #75 (permalink)
srtboy's Avatar
Member Number: 3980
Trader Rating: (15)
steve i think we should turn the fuel pressure up on yours too and just take out more fuel up top with the SAFC. maybe that's been the problem with your sputtering and misfiring. i think your PCM is pulling tons of timing while at the same time your dumping loads of fuel in there! next time you dyno, try it!
BTW Dognutz, thanks for everything you're doing here, it may also be the reason i've had disappointing numbers with my 50 trim turbo kit.
sweet is right!!!
John
SRTOC Member# 514
srtboy is offline   Reply With Quote
