Old 01-11-2005, 06:21 PM   #31 (permalink)
dognutz's Avatar
Member Number: 14819
Trader Rating: (15)
Quote: Originally Posted by Vector
tail sniffer or o2 bung id get it double checked like a LM1, o2 and what ever they are using just to make sure its working right... do you ahve a wideband?
if so whats the a/f on the street... dynos lie sometimes
anyways you should be richer then that with those injectors and a FPR
turning up static might help some but youll have to end up taking more out of the other palces to i am guessing
i have aem uego.. street dont know haven't got on it and look yet.. its more like 4000 rpm start to work its way down to 12.1 on top 6500 rpm.. also thay tuned it with the one that goes in tail pipe..
HOME OF THE MOST HP SRT4 ON NO SPRAY!! WITH 31psi BOOST
FOR ALL YOUR NEEDS RAGE-TEK IS THE ANSWER
Shop (954) 978-0978
Cell (954) 274-4175
http://mike-castaldo.tripod.com/
also check herehttp://home.comcast.net/~extreme1neo...ome.html-.html
dognutz is offline   Reply With Quote
Old 01-11-2005, 06:28 PM   #32 (permalink)
SRToc Member
metfan2000_99's Avatar
Member Number: 2980
Hey Mike Nice numbers dude!! I cant wait to see mine like that!
List of mods:
AGP T3/t04 50 trim
AGP FMIC
AGP CAI
AGP Fuel kit (SAFC-2)
AGP Hard Pipe
Return Fuel Line
HKS SSQ BOV
Motor Mounts
metfan2000_99 is offline   Reply With Quote
Old 01-11-2005, 06:29 PM   #33 (permalink)
Member Number: 11555
dognutz, what injectors you using?
ToFu is offline   Reply With Quote
Old 01-11-2005, 06:31 PM   #34 (permalink)
dognutz's Avatar
Trader Rating: (15)
750cc
Old 01-11-2005, 06:33 PM   #35 (permalink)
dognutz's Avatar
Trader Rating: (15)
that tune i gave you is good for 352 hp and tq 369.. i am not happy about my hp number but damn this car is a tq monster.. talk about snaping your neck back.
Old 01-11-2005, 06:33 PM   #36 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
AEM uego can data log to a laptop i think.. or to itself and then DL to a laptop
if you can do this
go out make a 3rd gear pull 2800-6500
put up a picture of what the A/F looks like
so above 4000 RPM its leaner... 13-1? and working down to 12.1 ?
this is very important stuff
please let us know
Vector is offline   Reply With Quote
Old 01-11-2005, 06:35 PM   #37 (permalink)
BlackSRT-4U's Avatar
Member Number: 890
Trader Rating: (29)
750cc
well they are not actually 750cc's anymore if you lower the static pressure to 41psi... you need to altleast bring up the pressure to 43 and up with out the hose connected.. if you want to solve the problem of the timing being pulled.. bring up the pressure to about 48-50psi hose off.. and pull fuel from the AFC.. if you have a 1to1 regulator it will bring up the pressure up top to compensate for the fuel you are taking off on the AFC.. you need someone that knows how to tune SRT's any one that knows about this cars know's that adding fuel on the AFC means timing being pulled...
BlackSRT-4U is offline   Reply With Quote
Old 01-11-2005, 06:37 PM   #38 (permalink)
Member Number: 2584
Trader Rating: (35)
Dognutz, why are you running out of fuel considering you got RC 750's and running a return kit w/ absolute manifold pressure of 50 (and 41 at idle).
There's something funky going on man, and it ain't me.
You car should be pee-ing gas, not running lean. You sure your fuel pump ain't borked?
For people using the SAFC and tuning on the street and the dyno (S1).
Make sure you pull at *LEAST* 4% fuel (across the board), or your car will be backfiring MOFO.. (will hit spark cut due to boost).
funks is offline   Reply With Quote
Old 01-11-2005, 06:42 PM   #39 (permalink)
Steven Burgess's Avatar
Member Number: 1515
I agree with Funks on this one. With the return set-up 1:1 some srt's are only running 35psi base and still having to pull out a lot of fuel on top.
Steve B.
Custom 60-1 turbo
434hp 419torque @ 25psi
7.7@95mph
Stock turbo, 295whp @ 21psi 7.9@88.8mph
Local Sponsor: www.4totalperformance.com
Steven Burgess is offline   Reply With Quote
Old 01-11-2005, 06:43 PM   #40 (permalink)
dognutz's Avatar
Trader Rating: (15)
50 + 26 (your boost reference at that PSI) = 76 psi fuel pressure = 991 cc/min
You car should be pee-ing gas, not running lean..
i have no clue.. i think its the stage 2 pcm.. if i raise the feul psi with vac of to 55 and bring the feul persure up with vac on to 43 psi what do you think.. well that stop timming for being pulled
Old 01-11-2005, 06:46 PM   #41 (permalink)
dognutz's Avatar
Trader Rating: (15)
come on guys give me fuel psi.. to shoot for..
Old 01-11-2005, 06:46 PM   #42 (permalink)
Member Number: 2584
Trader Rating: (35)
Word of advice man, check your fuel pump.. Cuz that fuel pressure is *WAY* UP there.. Especially for the numbers you putting out..
750's at 54 psi (max pressure @ boost) is more than enough to feed 400 WHP (around 835 cc/min).
Old 01-11-2005, 06:48 PM   #43 (permalink)
dognutz's Avatar
Trader Rating: (15)
if you can do this
please let us know
i cant right now its raining i will be all over the place..
Old 01-11-2005, 06:50 PM   #44 (permalink)
Member Number: 1515
Hey Mike, see if you can borrow someone elses fuel pressure guage just to make sure yours is reading right. I know it's un-likely to be bad, but it's something you could eliminate pretty easy.
Steve B.
Old 01-11-2005, 06:51 PM   #45 (permalink)
dognutz's Avatar
Trader Rating: (15)
okay what am i checking for.. i got a block off on stock reglutor in the pump tank.. its a lil alum bushing.. i thought i should have enough feul..
