Old 01-11-2005, 05:35 PM   #16 (permalink)
dognutz's Avatar
Member Number: 14819
Trader Rating: (15)
Quote: Originally Posted by Ben K
Not bad at all Mike with with the stage 2 PCM. Nice timing retard there at about 5000rpm. Gotta love stage 2.
how the hell do i stop that.. do i put a map clamp on or what.. i got one if i need it or do i just put my stock pcm in with stock map and tip..
HOME OF THE MOST HP SRT4 ON NO SPRAY!! WITH 31psi BOOST
FOR ALL YOUR NEEDS RAGE-TEK IS THE ANSWER
Shop (954) 978-0978
Cell (954) 274-4175
http://mike-castaldo.tripod.com/
also check herehttp://home.comcast.net/~extreme1neo...ome.html-.html
dognutz is offline   Reply With Quote
Old 01-11-2005, 05:36 PM   #17 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (71)
That run was clearly on it's way to 400+whp but the S2 yanked all your timing. That's way all the S2 guys tune with a map clamp.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 01-11-2005, 05:45 PM   #18 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (372)
DAMN IT...beat me to it again. You bastids. I was just reading this thread and was going to chime in....dohh!
aaron
Look for 9s with a manual very soon!
10.62@133.8
10.64@136.7
CSRT4 In house! http://www.caliberforums.com/forums/...ead.php?t=5153
Old 01-11-2005, 05:51 PM   #19 (permalink)
dognutz's Avatar
Trader Rating: (15)
i got map clamp i will put it on and have dyno again..
Old 01-11-2005, 05:56 PM   #20 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (71)
You want to find a way to make sure the PCM doesn't see a map voltage equivalent to around 19psi of boost with the stage 2. One way to do that would be a map clamp, however using a map clamp with a SAFC is useless since one would be overriding the other.
Increase your fuel pressure such that you'll be decreasing the voltage the PCM sees by "removing" fuel via the SAFC.
Old 01-11-2005, 05:57 PM   #21 (permalink)
Member Number: 13362
Trader Rating: (109)
Have you track tested it yet ? I have not put mine on a dyno yet , but I was very happy with my track times last wednesday at the track @ 24 PSI doing constant traps between 119 & 121 MPH and geting low 12's all day on 93 octane pump gas , & mine is still not even tuned perfect . P.S. Thanks AGP .
2.4TURBOMAN is offline   Reply With Quote
Old 01-11-2005, 06:01 PM   #22 (permalink)
dognutz's Avatar
Trader Rating: (15)
okay okay with that said.. i am useing fuel persure 50 vac off and 41 vac on.. do i raise it with vac off. and to what do you think.
Old 01-11-2005, 06:02 PM   #23 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
Mike....
really we need to see the A/F just telling us its 12/1 does not mean poo
do you have a scan or anything of the a/f
is it 12/1 and looks like this __________________________________________
or does it look like its all over the place... is 12/1 the leanest it gets ?
hows the clutch in the car that could be a problem to
Are you pulling any fuel from 5000-6500?
post up that A/F ratio and your problems wil lstart to go away there is enough people here that know what to do
Vector is offline   Reply With Quote
Old 01-11-2005, 06:02 PM   #24 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (71)
Mike,
Post your SAFC High Throttle settings across the board.
Old 01-11-2005, 06:04 PM   #25 (permalink)
dognutz's Avatar
Trader Rating: (15)
no not yet track r close anround here because of winter will open again march..
Old 01-11-2005, 06:09 PM   #26 (permalink)
dognutz's Avatar
Trader Rating: (15)
Mike,
1000 to 3800 -20%
4200/-19%
4800/-21%
5400/-18%
5800/-8%
6200/-5%
Old 01-11-2005, 06:12 PM   #27 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
Quote: Originally Posted by dognutz
1000 to 3800 -20%
4200/-19%
4800/-21%
5400/-18%
5800/-8%
6200/-5%
4200/-19%<---------good
4800/-21%<---------good
5400/-18%<---------good
5800/-8%<---------PCM seeing to much boost needs more fuel
6200/-5%<---------PCM seeing to much boost needs more fuel
what is the A/F from 5500-6500 in 100 RPM incraments
Old 01-11-2005, 06:12 PM   #28 (permalink)
dognutz's Avatar
Trader Rating: (15)
Quote: Originally Posted by Vector
Mike....
don't have that sheet.. i will have to get it.. from 5000 up is 12.1 across the board..
Old 01-11-2005, 06:14 PM   #29 (permalink)
dognutz's Avatar
Trader Rating: (15)
raise fuel persure vac on or off. right now 50 vac off and vac on 41psi..
Old 01-11-2005, 06:18 PM   #30 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
tail sniffer or o2 bung id get it double checked like a LM1, o2 and what ever they are using just to make sure its working right... do you ahve a wideband?
if so whats the a/f on the street... dynos lie sometimes
anyways you should be richer then that with those injectors and a FPR
turning up static might help some but youll have to end up taking more out of the other palces to i am guessing
