Old 09-25-2009, 08:42 PM   #1 (permalink)
Member Number: 68561
Default Do you still need Fuel Pump re-wire even if u are going 2 use Walbro255
hey guys i just want to get thing clear in my mind before i spend the money and down the road i realize it was a waste.
Do you still have to do a fuel pum re wire even if you are putting high volume pump?
Please let me
b3rz3rkACR is offline   Reply With Quote
Old 09-27-2009, 01:47 PM   #2 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
Then its even more important. The rewire is giving the pump a more reliable supply of power because the stock wires are to small. A higher volume pump could also use the more reliable power supply.
Welcome to the forums.
porksword is offline   Reply With Quote
Old 09-27-2009, 01:48 PM   #3 (permalink)
Senior Moderator
kritical's Avatar
Member Number: 49262
Trader Rating: (138)
^ couldn't have been said better..
stock
kritical is offline   Reply With Quote
Old 09-27-2009, 02:53 PM   #4 (permalink)
Member Number: 31038
Trader Rating: (50)
Stupid question but I am curious anyways. Will the Fuel Pump Rewire cause the injectors to run harder since its getting more voltage with the fuel pump rewire causing more fuel to the injectors... Maybe PCM is not calibrated for this?
raul-01 is offline   Reply With Quote
Old 09-27-2009, 06:43 PM   #5 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
the fuel pressure regulator will still limit the flow but the pump will get a constant high voltage and #1 run cooler and #2 be able to supply more fuel when its needed (dictated by fuel pressure)
running 2 pumps on 1 leg will show a severe voltage drop making amperage rise this can damage the pump in a short period of time
Old 09-27-2009, 06:45 PM   #6 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
is it safe to run one rewire to two pumps?
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 09-27-2009, 06:48 PM   #7 (permalink)
nutz's Avatar
Trader Rating: (19)
yes if the relay is rated for the amperage draw of both pumps and the wire must be able to handle the added draw also (everything will need to be beefed up)
you dont want wimpy relays or wires to catch fire
Old 09-27-2009, 06:50 PM   #8 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
just debating if i should purchase to another rewire thats all.
this the one i use:
Painless Wiring 50102 - Painless Performance Universal Fuel Pump Relay Kits - Overview - SummitRacing.com
Old 09-27-2009, 07:15 PM   #9 (permalink)
nutz's Avatar
Trader Rating: (19)
I would do 1 relay (big beefy sucka) and some serious wire K.I.S.S.
Old 09-27-2009, 08:16 PM   #10 (permalink)
porksword's Avatar
Trader Rating: (21)
Big relay and large wire will do a fine job for 2 pumps. Or you can use a seperate 30 amp fog light relay ($5 from the autoparts store). Run all the wires the same and just split or tap into the original wire just for a signal to turn on the relay. You could run 30 pumps on seperate relays if you wanted to without any negative effects.
Kind of like the Blue (remote on) wire on a car stereo, it just gives a 12v signal and tells the amps to turn on, but doesnt draw hardly any power at all.
Old 09-27-2009, 11:51 PM   #11 (permalink)
matthew00029's Avatar
Member Number: 46349
Trader Rating: (21)
What? I'm a gen tech and what I was tought you can't have amperage without voltage...If voltage drops so will amperage...
05 Black SRT-4 ACR Almost there
matthew00029 is online now   Reply With Quote
Old 09-28-2009, 12:24 AM   #12 (permalink)
nutz's Avatar
Trader Rating: (19)
yea maybe i coulda worded that better , with resistance from thin wires the voltage will drop requiring more amperage to keep the pumps going then poof (i have no idea but i know it will be bad )
Old 09-28-2009, 01:56 AM   #13 (permalink)
Trader Rating: (21)
Thin wires provide almost no resistance...A bad connection or corrosion will effect voltage not the wire size. Voltage does no work at all, its all amps.
Old 09-28-2009, 08:14 AM   #14 (permalink)
Please let me
thx alot guys. no im am clear.
Old 09-28-2009, 10:49 AM   #15 (permalink)
nutz's Avatar
Trader Rating: (19)
thanx, so thicker wires allow the amount of amps
that makes sence
Page generated in 0.20838 seconds with 13 queries
