Ive been looking for a E85 proofish fuel sensor. I see some forum members are making some but don't see any reviews. Are there any reviews about the Dcr sensors. Im really in the need of a Sensor. Any up to date input on E85 fuel sender would be appreciated.
How are you going to use it? Install so you can see what e85 numbers the last fill up is reading? Take a look at the Zeitronix one or you can build your own using a GM OEM sensor.
I think he's talking about the fuel level sensor. If that is the case, DCR is very expensive for what it is. I have one that has been in e85 for 4-5 years without fail. I got it out of a 2000 neon at a junkyard. In all honesty I would just pay attention to how many miles you have on your tank and fill up around 200. Note how much fuel you take and adjust accordingly.
I've had two DCR senders fail. I'm going to try a van flex fuel sender , I have a Duster360 tune with a modified voltage table that might give good readings.
