Old 10-27-2009, 05:28 PM   #106 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (50)
Quote: Originally Posted by GreaseMonkey69 View Post
3 stations here. sometimes they run out so i keep a extra 5 gal for just "in case" situations.
the inline 044 looks like a good solution for me running E85. now i need to invest in a aftermarket rail more line and a pump obviously.
nachO.. how much did it cost to get that custom fuel sock/fitting for the 044?
did you just hard solder the connections to the pump or did you use the connector that came with the stock setup?
pump is $183 on ebay and the sock is $50 from this one place (i have to find the link again).
JnR's quest for 10's will be done with the help from OUR TRUSTED VENDORS: AGP, RAGE-TEK, DCR, CNCport, REALTUNE PERORMANCE
reed32 is offline   Reply With Quote
Old 10-27-2009, 05:33 PM   #107 (permalink)
Super Moderator
SRT of the Month
Member Number: 39843
Trader Rating: (183)
Jay Racing has the sock
Old 10-27-2009, 05:34 PM   #108 (permalink)
julius717's Avatar
Member Number: 24352
Trader Rating: (17)
Bosch Fuel Pump Pre-filter Fuel Sock For 044 [BFP-PF1] - $50.00 : Jay Racing
DRASTIC
I dont play to play, I play to win.
julius717 is offline   Reply With Quote
Old 10-27-2009, 05:39 PM   #109 (permalink)
luke7019's Avatar
Member Number: 60398
i need to find that same fitting nacho has on top of his pump, i already have the pump and the sock...anybody?
aem ems - e85
03/04/2010 R.I.P stock motor
FS: dual scan gauges and mopar 3 bar map/tip, pm me
luke7019 is offline   Reply With Quote
Old 10-27-2009, 05:40 PM   #110 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (50)
for those of you trying to make your own twin pump set up here is one way to do it. its a ok starting point but i would run a boost relay so the pump isnt always on.
710-65160 FUEL BLOCK Y-TYPE 24.99
555-110165 #10 PORT TO #6 FLARE BLCK 10.99
023-FCE1532 #6 90DEG SCKTLS HOSE END 22.99
555-102021 #8 PUSH LOC HOSE 10' BLK 27.99
555-102011 #6 PUSH LOC HOSE 10' BLK 24.99
361-985086 FTG -6 PORT TO -8AN 9.99
361-700109 FTG -8 STR - 1/2" HOSE 4.69
555-15175 FUEL FILTER S/S 3/8" BARB 16.99
Old 10-27-2009, 05:40 PM   #111 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (23)
thanks reed and uncommon. i am in the process right now of dropping the fuel tank (leaking bulkhead fitting) so i bought some new fittings for -6AN setup from the pump through the canister when i upgrade. just pricing the next list of things to do to the car.
off topic though..
uncommon i know you used stat o seals on your return setup. do you know about these plastic washers that are used to seal up fittings like a bulkhead fitting? i know ordering those would have my car down for a few days and 1 place here had these seals that are alcohol and fuel safe.
GreaseMonkey69 is offline   Reply With Quote
Old 10-27-2009, 05:48 PM   #112 (permalink)
Trader Rating: (23)
the pump inlet is M12 x 1.5. you can go get a metric to -AN fitting adapter or metric M12 x 1.5 to a standard NPT thread. -6AN is about 3/8 and 8-an is about 1/2 in. so look for a M12x 1.5 to a 1/2 threaded fitting. then screw a 1/2 in barbed fitting
Old 10-27-2009, 05:55 PM   #113 (permalink)
luke7019's Avatar
im going to use a m12x1.5 to -6an, then a -6an pushlock...that will work right?
Old 10-27-2009, 06:03 PM   #114 (permalink)
Trader Rating: (23)
yes i don't see why not. i would use some good hose too. i like using the aeromotive push loc hose. 300psi burst strength and safe for fuel and alcohol's.
when i do a 044 im going to do pretty much what you are going to do.
Old 10-27-2009, 06:07 PM   #115 (permalink)
NachO_SRT's Avatar
Member Number: 8662
You fellas going to a -6 feed need to look close at your horsepower goals. With E85 or any alky based fuel you need to think more about volume @ pressure.
-6 did not meet my Volume needs for a feed line.
I'm -8 Feed -8 to Magnafuel regulator and -6 back to the Qeasy.
NachO
Daily Driver -2009 SWP WRX STi + Gold BBS's
Road Course Car. 2004 E-blue SRT-4, Mods and pics: CLICK
7/18/09 - 507/468 - S259 Fuel E85 - Meanblueberry.
STOCK:308/396 - 5/17/2009 E-85, Stock turbo
NachO_SRT is offline   Reply With Quote
Old 10-27-2009, 06:15 PM   #116 (permalink)
Super Moderator
SRT of the Month
off topic though..
Never seen them. Post up a link. I changed up my setup last winter, drove the car probably 5 times this year and I'll more than likely be changing it again this winter LOL.
NachO
I think I'm gonna ditch my -6AN feed for a -8AN. I would think my -6AN aero regulator would work fine since it's post rail.
Old 10-27-2009, 06:31 PM   #117 (permalink)
Trader Rating: (23)
yea here is the link. they are teflon washers
Russell Performance - Service Parts
well when i upgrade the pump i will upgrade the fuel feed system. stock 5/16 line is too damn small. my -6AN return will be just fine. now i know -8 will be pretty sufficient for my future E85 setup.
Old 10-27-2009, 06:42 PM   #118 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (50)
NachO
-8an and -10 an work for me
Old 10-27-2009, 06:43 PM   #119 (permalink)
luke7019's Avatar
im sure ill be fine with -6an feed and -4an return since im on pump/meth...not e85
Old 10-27-2009, 06:50 PM   #120 (permalink)
NachO_SRT's Avatar
Member Number: 8662
Your correct the Reg is A-ok to be -6. The feed really needs to be -8 or larger on alky based fuels.
Luke: your fine on pump with -6 -4
