hey nacho I just got the pump, what size fitting is on the outlet side, I ordered a -6 fitting from jay racing but I think thats for the inlet side
from their site
Inlet is M18 x 1.5mm female, outlet is M12 x 1.5mm female. Positive terminal is M6 stud, ground terminal is M5 stud. We try to include the hardware for these (nuts and lock washers) when we can since Bosch decided not to do so.
great thanx
also is their a special type of wire to use for the gasoline enviroment
I used Fuel safe Wire. My neighbor is a Wire guy. Works for a cable company. I got 2 spools of Fuel safe wire that is used in Generators and heavy equipment. I'll get the specs for it later today and post them.
Anyone else F'd by DST? Jesus it's 4:30 and I'm awake....I feel like an old man.
i think he is talking about the pins that you can crimp down and insert the pins into the fuel pump harness/clip so all you have to do is run the wiring from the pump and remove the two old smaller wires from the fuel pump canister and insert new larger wire into the clip.
yea, I was really hopping I wouldn't have to reuse the stock pins but its looking next to impossible to find new ones. if I'm careful and use some good solder & shrink wrap they will probably hold up
for the top fittings go to OSH.
part#'s
9073495 (1/4 flr x 1/4mpt adapter)
9061433 (3/8 brb x 1/4fpt adapter)
