Here is what you need to do this mod.
1) Bottle neck fix
2) Return line
3) 2 bosh 044 fuel pumps.
and these:
How I got to the 044 in tank solution:
I started with a Walboro 255 in tank with the fuel pump rewire, it died when asked for 100psi.
I wanted a base rail pressure of 70 psi with my Injector Dynamics 1000CC's, these are plug and play so no driver box was needed and they came with a nifty little flow chart that gives me "dead times" at different voltages and flow at different pressures. the 044 has no issues up to 120psi. Perfect for my 100psi max.
@ 100psi The ID 1000's flow 1525CC.
Here is a pic of the kit, this one is for an evo, SRT's do not need anything but the direct fit, plug and play injectors. If you view the image full size you can see the deadtime and flow chart clearly.
On to the 044 in tank pics.
This (left: walboro 255) to This (right: bosh 044)
Getting started:
Test fitting, I tried to keep the bottom end intact fitment didnt quite work out that way as you will see:
Here you can see it gets close to "fitting, but, thats as far inward as the 044 can go.
PLAN B, GUT THE SUCKER!
I wanted to maintain the "fuel sock" in tank pre filter set up. This would ensure that the feeding pump was getting as clean a fuel flow as I could account for.
Modified by KC set me up with a killer fuel sock attachment for the 044.
Here she is all completed and back together:
And reinstalled in the car:
As always, if you have any questions feel free to ask them here for all to share, or by PM.
Thanks for looking
NachO
