Old 04-17-2008, 07:36 PM   #1 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (82)
Boomba rail modification
Sorry if this has been covered...has anyone with a boomba rail had to modify/grind off one of the edges because it hits the coolant pipe???
Im looking at mine and size it up and its close, just seeing if others have had this issue?
WANT TO BUY: Rota Subzero's...Any color is fine...Any size is fine. PM me.
Old 04-17-2008, 07:40 PM   #2 (permalink)
bordeniuk's Avatar
Member Number: 46198
Trader Rating: (77)
not me. pics?
bordeniuk is offline   Reply With Quote
Old 04-17-2008, 07:50 PM   #3 (permalink)
Trader Rating: (82)
Quote: Originally Posted by bordeniuk View Post
not me. pics?
yours doesnt hit the coolant hose at all?
Old 04-17-2008, 08:08 PM   #4 (permalink)
bordeniuk's Avatar
Trader Rating: (77)
nope
Old 04-17-2008, 08:32 PM   #5 (permalink)
Scammer
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (45)
mine hits it also......its only with rc length injectors that there is a problem....i also need to find some way to plum a fitting onto the passenger side end to run a return the right way i will be set
onthedwnlow is offline   Reply With Quote
Old 04-17-2008, 08:35 PM   #6 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (95)
mine did, sold it. also couldnt get it to seal with my rc 750s
J & R PERFORMANCE
Old 04-17-2008, 08:35 PM   #7 (permalink)
bordeniuk's Avatar
Trader Rating: (77)
thats weird. i have rc's and mine doesnt ever come close
Old 04-17-2008, 08:43 PM   #8 (permalink)
bordeniuk's Avatar
Trader Rating: (77)
never had those issues either. me or david
Old 04-17-2008, 08:44 PM   #9 (permalink)
Scammer
Trader Rating: (45)
i have yet to see a set of rc's on a boomba rail that does not hit......
its not the rc's that have a problem sealing on the rail....its the spacers you use to space the rail back.....there too long.....i have seen rc's that dont seal right on fatory rails because the spacers are too long
Old 04-17-2008, 08:45 PM   #10 (permalink)
bordeniuk's Avatar
Trader Rating: (77)
well i post a pic tomorrow of my rail and rc's.
Old 05-14-2008, 10:00 AM   #11 (permalink)
AltersEgo's Avatar
Member Number: 12167
Trader Rating: (33)
I am also having a problem with the RC 750's sealing on the Boomba rail. I used 7/16ths nuts as spacers. Could they possibly be too high? They seemed to work with the stock rail.
AltersEgo is offline   Reply With Quote
Old 05-14-2008, 10:07 AM   #12 (permalink)
Scammer
Trader Rating: (45)
what i like to do is put the injectors all the way in the rail.....then put the whole rail down in the intake mani and the measure the distance they are and either cut new spacer or just uses a few washers.......most boomba rails only need 2-3 washers stacked up.......so thats prob some where around 3/16.....the boomba rail will require less spacer height
Old 05-14-2008, 11:36 AM   #13 (permalink)
AltersEgo's Avatar
Trader Rating: (33)
Looks like you're right. I just put my stock rail back on, and the boomba rail actually had to be tilted back a bit to fit those nuts in there. Also, I noticed that the O-Ring on the schrader valve side was split in half.
Old 05-14-2008, 10:31 PM   #14 (permalink)
bordeniuk's Avatar
Trader Rating: (77)
im gonna go take pics of my rail real quick i forgot to when this thread was made a while ago
Old 05-14-2008, 10:46 PM   #15 (permalink)
bordeniuk's Avatar
Trader Rating: (77)
i dont really know what these pics are gonna do for you all that are having problems but mine clears, may not be by much but i dont notice and chafing on the hose or housing. so its good enough for me
