boomba fuel rail - Dodge SRT Forum
post #1 of 11 (permalink) Old 04-05-2012, 09:36 AM Thread Starter
DavidsSRT-4's Avatar
Quoted: 0 Post(s)
boomba fuel rail
So I installed a boomba fuel rail yesterday with outthe a return lineline and my car seems to act a little different. I know the stock rail has a diaphragm on it to absorb the fuel pumps surging and the boomba fuel rail doesn't have one. Could this make my car a little erratic at take off? Maybe a return line will fix it?
I have plans in the near future to run a return line with a dw300 pump
300+hp 360 tq STOCK TURBO!
13.22 at 105mph* (with boost leak)
stage 2 and stuff
THIS YEAR 12's OR BUST!
DavidsSRT-4 is offline
post #2 of 11 (permalink) Old 04-05-2012, 10:42 AM
Vipercar93's Avatar
Quoted: 1 Post(s)
Did you cut a seal on an injector? Did you lube them up a little when you put it back together? I have never had a problem.
Totally Stock down to the KDW's... Best 1/4 Time
13.771 @ 101.2 MPH 2.113 60ft.
Vipercar93 is offline
post #3 of 11 (permalink) Old 04-05-2012, 11:00 AM
racedude1984's Avatar
Quoted: 0 Post(s)
I ran my boomba for a long time without return line maybe you didn't get an injector seated right.
SCH-I500 using
Old school!
racedude1984 is offline
post #4 of 11 (permalink) Old 04-05-2012, 11:57 AM Thread Starter
Quoted: 0 Post(s)
Yes to both I made sure they seated correctly and even cleaned out the intake holes and wiped down the seals. Maybe its in my head. The weather has been crazy at my place heavy rains then sunny days the next day maybe my cars just freaking out a little
stage 2 and stuff
post #5 of 11 (permalink) Old 04-05-2012, 12:11 PM
Vipercar93's Avatar
Quoted: 1 Post(s)
How did you clean the holes? You might have accidentally caused an injector to dribble.
post #6 of 11 (permalink) Old 04-05-2012, 02:47 PM Thread Starter
Quoted: 0 Post(s)
Finger rags a pic and brake clean only on the holes I wiped the o-rings with a rag and hands
stage 2 and stuff
post #7 of 11 (permalink) Old 04-05-2012, 03:41 PM
Vipercar93's Avatar
Quoted: 1 Post(s)
My bet is you damaged the injector with the pic, causing the injector to dribble. Those holes are fairly precise. Fueling wise under power I don't think it's as much of an issue, just causes drive-ability problems since the nozzle cannot atomize the fuel right under light cycles. Either that or you pushed debris into the injector. Your problem defo sounds like an injector acting funny IMO. There should be enough volume in the boomba rail to not have to worry too much about the pump pulses.
post #8 of 11 (permalink) Old 04-05-2012, 05:43 PM Thread Starter
Quoted: 0 Post(s)
No no no. I didn't touch either opening of the fuel injectors only the o-rings and the intake manifold holes that the injectors go into
stage 2 and stuff
post #9 of 11 (permalink) Old 04-11-2012, 02:22 PM Thread Starter
Quoted: 0 Post(s)
Could a fouled spark plug cause a problem? Lol
stage 2 and stuff
post #10 of 11 (permalink) Old 04-21-2012, 12:34 PM
Salty SRT's Avatar
Quoted: 0 Post(s)
To the OP, I seem to have the same/similar problem. When the car is cold, it just seems to bog when you go to take off. I have been meaning to swap back to the stock rail, and then back again to see if it is the rail causing the problem.
Salty SRT is offline
post #11 of 11 (permalink) Old 04-21-2012, 12:53 PM
SRTForums Member
2011 Calendar Car
Topsey_kretts's Avatar
Quoted: 0 Post(s)
when i put the boomba on my car, i couldnt tell any difference. Replace teh spark plugs and see if that fixes it..
Wait a minute, Doc. Ah... Are you telling me that you built a time machine... out of a DeLorean?
Topsey_kretts is offline
User Tag List
Linear Mode Linear Mode
