Old 09-20-2009, 06:49 PM   #1 (permalink)
Member Number: 75234
Default Bogging out at 3000 rpm and greater
Hi guys. I'm new here so bear with me. My stepson has a 2000 Neon SRT4 with some type of turbo and boost control. I don't know all the tech specs about the car since it's not mine, but if you need them I'll get them. Anyway, yesterday he said it bogs out when the engine is higher the 3k rpm. He can still get highway speeds and below 3k is ok, it's just higher than 3K. Where do we begin to look?
buster-boy is offline   Reply With Quote
Old 09-20-2009, 07:57 PM   #2 (permalink)
bumble_bee_srt-4's Avatar
Member Number: 56601
i would suggest checking spark plug gaps, btw the srt-4 was only made from 2003-2005... check the plugs, also look for boost (vacuum leaks)
bumble_bee_srt-4 is offline   Reply With Quote
Old 09-20-2009, 08:21 PM   #3 (permalink)
Thanks BB, I'll tell him that. Like I said, I don't know all the tech specs and he's standing over my shoulder telling me "No, it's a 2003. Guys are probably laughing at you right now".
Anything else you can suggest for me?
Old 09-20-2009, 08:42 PM   #4 (permalink)
Member Number: 3387
Trader Rating: (15)
First off, when did this start? If it just started happening, check for boost/vacuum leaks. If it has been on going then I would say like the previous poster, check your spark plug gap. Should be around .035 - .038. If it is wider than that your boost from the turbo will blow the spark out. Let us know and we can help you further.
Keep your signature clean
edited by Peteblksrt4
jiggalude is offline   Reply With Quote
Old 09-20-2009, 08:49 PM   #5 (permalink)
Member Number: 71225
plugs&wires probably
AnsareStg0 is offline   Reply With Quote
Old 10-13-2009, 03:21 AM   #6 (permalink)
Member Number: 64975
had the same problem it was my camshaft positioning sensor. was like 33 bucks at advance or 60 at dodge in stock.
robh62788 is offline   Reply With Quote
Old 10-16-2009, 01:08 AM   #7 (permalink)
Member Number: 61967
Lucky, you got the 2000 limited edition . I would also chime in on cam position sensor but remembered mine not reving over 2500 or something low, don't remember, feels like you hit the rev limiter. Also does it takes a few times to crank? If it starts right up I doubt its the CP sensor, probably like mentioned, check wires/gap.
Stock Turbo
Salty SRT is offline   Reply With Quote
Old 11-04-2009, 12:31 PM   #8 (permalink)
Member Number: 76002
Default hai
CarsAddict is offline   Reply With Quote
Old 11-06-2009, 09:23 PM   #9 (permalink)
gump1114's Avatar
Member Number: 28766
Trader Rating: (12)
if it's the cam position sensor it should throw a cel. I'd lean more towards the plugs/wires.
Broken-ISH.
gump1114 is offline   Reply With Quote
Old 11-06-2009, 09:37 PM   #10 (permalink)
BlueSRT4Trouble's Avatar
Member Number: 42999
Trader Rating: (29)
Do you have a fuel controller on your car? What one?
I had the same problem a few months back, it was the SAFC some how it went from reading pressure to Kerman or what ever it is. Switched it back problem was solved.
(Rest in piece Mark Riley Turbo Tune, 9-7-49/12-4-08)
BlueSRT4Trouble is offline   Reply With Quote
Page generated in 0.12872 seconds with 13 queries
