Old 09-29-2009, 01:57 AM   #1 (permalink)
vandido626's Avatar
Member Number: 42019
Default bad fpr or pump?
so lately ive been having a lot of hard starts and i was wondering if my aeromotive fpr went bad or is it my fuel pump? when i turn the key to the ON position and wait a couple of seconds before i crank it, it'll start right up. but when i check the fuel pressure after i turn off the car its at 0. so whats the problem?
vandido626 is offline   Reply With Quote
Old 09-29-2009, 02:24 AM   #2 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
if you have a stock fpr/filter in the canister take it out and check the O-rings and plan on doing a bottleneck fix to eliminate the problem
Old 09-29-2009, 02:59 AM   #3 (permalink)
vandido626's Avatar
the bottleneck fix connects the return line to the pump right?
Old 09-29-2009, 08:39 AM   #4 (permalink)
Member Number: 75282
Injectors leaking?
1995 Dodge Stealth RT/TT
335AWHP - 8.2@82.x (1/8 mile) - w/ stock 9b's
TD04-13Gs | Dejon Blow-thru Intake pipes | Dejon FMIC | Megan Racing Downpipe | IPS Single 3" Exhaust | 450cc dual spray pattern DSM injectors | Autometer Ultra Lite Boost A/F, & EGT gauges | MAF-T v1 | TXS RFL BOV | 3SX Radiator | Flexalite fans | Custom MBC
alottaboost is offline   Reply With Quote
Old 09-29-2009, 09:43 AM   #5 (permalink)
bizman69's Avatar
Member Number: 40768
Trader Rating: (45)
Nope. The return line either feeds back into your filler neck or the fuel canister. Do what nutz said. Pull the stock fpr and see if the black or ring is missing or seeded wrong.
bizman69 is offline   Reply With Quote
Page generated in 0.15283 seconds with 13 queries
