Old 12-30-2009, 05:22 PM   #1 (permalink)
jonnybuff4life's Avatar
Member Number: 73238
Default anyone have an in-line fuel fliter?
thinking about installing one along with new fuel lines..anyone have this done to help me??
jonnybuff4life is offline   Reply With Quote
Old 12-30-2009, 05:33 PM   #2 (permalink)
NachO_SRT's Avatar
Member Number: 8662
I do.
What questions do you have?
NachO
VOTE FOR ME! AUG 2010 SRT of the Month!
http://www.srtforums.com/forums/f389...thread-576826/
DD -09 STi | Track Car. 2004 E-blue; Mods and pics: CLICK
S259@ 25psi:614/567 -6/10, E85 - Meanblueberry.
NachO_SRT is offline   Reply With Quote
Old 12-30-2009, 05:36 PM   #3 (permalink)
quicky4's Avatar
Member Number: 28222
Almost any performance company makes them. You can usually pic them up at your local peformance or hot rod shop or through jegs or summit. Very easy to find.
Being a jack of all trades allows you to be a master of none - Electromotive
Powered By: Borg Warner/Airwerks, Full-Race, Rage-Tek, Electromotive, and TiAL
quicky4 is offline   Reply With Quote
Old 12-30-2009, 07:18 PM   #4 (permalink)
SRT of the Month
Member Number: 33203
Anyone who has done a bottle neck mod should have done this. I believe mines an earls filter. It's been a couple of years since I did it so I could be wrong.
My name is Jon, there's no H in it.
In the process of rebuilding.
Precision 6262
I<3 Haters.
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is offline   Reply With Quote
Old 12-31-2009, 05:25 AM   #5 (permalink)
first off im not sure if i should do it or not thats why im asking.lol.what kinda lines would u use after removing stock?
Old 01-06-2010, 12:49 PM   #6 (permalink)
blackturbo-4's Avatar
Member Number: 70282
in for some more info on running inline fuel filter
corn fed BWs256
tial 50mm bov, 3in see, 950cc's, bosch 044 fuel pump, -6an return line,-6an feed line, fuel rail, fuel pressure regulator, werks fmic, Ported intake manifold, 60mm TB, 3 bar map and tiip sensors, visteon racing radiator, wotbox 2step,scan gauge, solid mounts, traction bars, ipp coilovers, prothane suspension bushing kit
E85poor mans race gas
blackturbo-4 is offline   Reply With Quote
Old 01-11-2010, 09:13 PM   #7 (permalink)
KoldKill's Avatar
Member Number: 75970
ditto.
Quote: Originally Posted by darrell cox View Post
We are not Walmart.
Quote: Originally Posted by Monster View Post
Nobodyreallyknowswhatyoursayingbecauseofthelackofp aragraphsorperiods.
KoldKill is offline   Reply With Quote
Old 01-12-2010, 04:32 AM   #8 (permalink)
NachO_SRT's Avatar
Member Number: 8662
Your IN the wrong thread - Your info is in the fuel section in the 044 thread. read that and you WILL know.
NachO
Old 01-13-2010, 10:55 AM   #9 (permalink)
cokey's Avatar
Member Number: 17219
For clarifiacation.. best to go with a 100micron?
cokey is offline   Reply With Quote
Old 01-13-2010, 11:06 AM   #10 (permalink)
BDCarrillo's Avatar
Member Number: 59014
The rated filter size is the "smallest" particle that will be stopped. Therefore a 40 micron filter will prevent smaller bits from passing through than a 100 micron filter.
Keep in mind that smaller meshes may "filter" more effectively, but will need cleaning more often and may have a minimal negative effect on fuel flow and pressure.
That's why I'd recommend using an inline filter that is approximately twice the size of your line and purchasing adapters for the ends. IE: -6 AN fuel feed, use a -12 AN filter. Verify the actual size of the filter, as some -6 and -8 AN filters are the exact same body/filter element with different machined adapters.
Pony - 1989 5.0 LX Convertible - 200hp/266tq old 302
Ol' Girl - 1971 Mach 1
Skittle - 2005 SRT4 - 229hp/259tq stock 281/327 stg2 7.9@93 1/8th
Completely upgraded fuel system! Info, shopping list, pics, how-to!
BDCarrillo is offline   Reply With Quote
Old 01-14-2010, 06:06 AM   #11 (permalink)
cokey's Avatar
If your gonna have one that needs cleaning, where's the best spot to locate it? I'm guessing thgh, closer to the pump means better flow or it doesn't matter?
Old 01-14-2010, 07:13 AM   #12 (permalink)
BDCarrillo's Avatar
You may be able to find one with a shutoff, but it would probably be fairly expensive. In my setup I have it screwed right into the fuel rail inlet. Its going to be a very minor restriction regardless of where it is in the line. Your best bet would be to have it above the fuel tank, if possible, so the whole thing doesnt drain out if you open up the filter element.
If it's going to be below the level of the fuel tank I'd highly recommend a shutoff.
Old 01-14-2010, 07:48 AM   #13 (permalink)
cokey's Avatar
Cool thanks..
