Another stage 3 fuel component/specification thread - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 08-03-2012, 07:50 AM   #1 (permalink)
turbo-tony's Avatar
Member Number: 51821
Default Another stage 3 fuel component/specification thread
Ok first off my mods:
47lb E3
Stage 3 fuel pump/rail/PCM
DSP tuned
I've ran this setup now for about 3 years without problem untill now. I'm having issues under WOT and full boost. My power completely breaks up. Also i've developed an extended crank after sitting for a few hours. I re-gapped my plugs and replaced my plug wires with a spare set that I keep in my trunk. Problem still there of course. Naturally I check fuel pressure, at idle it's 45psi with vacuum applied to the rail regulator and without vacuum it's still 45psi. Judging by this I would say the regulator is bad due to no change in pressure. But from what I understand rail pressure on a stage 3 should be at 52psi and without vacuum 58psi, is this correct? If so this combined with the dropping fuel pressure while sitting would lead me to believe that the in tank regulator may be on its last legs. My question is can this be bought seperatly from the entire module? I searched and found a thread that's a few years old talking about a possible group by from the manufacturer but other than that I don't know. I really would like to keep the stage 3 components rather than get back into buying/tuning other parts again.
47LB E3
AGP WGA
Tuned
turbo-tony is offline   Reply With Quote
Old 08-03-2012, 08:40 AM   #2 (permalink)
Creamer03's Avatar
Member Number: 62203
I would go with a pump gettin weak way before a reg goin bad! Is it the original stg 3 pump? If so id throw a new Wally in and go from there.
Going for a Texas Top 10 1/4 mile spot...
Baby snail and E85...
Creamer03 is offline   Reply With Quote
Old 08-03-2012, 09:13 AM   #3 (permalink)
turbo-tony's Avatar
Yes original stage 3 pump. I know that they are put under high demand, mine certainly has. I bought a walbro a few years back but it was defective out of the box. Maybe 2nd times a charm
47LB E3
AGP WGA
Tuned
Old 08-03-2012, 10:13 AM   #4 (permalink)
Member Number: 11361
ditto -- fuel pump would be my guess, afr @ wot?
(while you're in there do a rewire)
to be 100% sure you'll need to measure fuel pressure under wot
Build Thread:http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline   Reply With Quote
Old 08-03-2012, 10:50 AM   #5 (permalink)
Creamer03's Avatar
I'd bet money its a pump! Mine was having similar symptoms as yours when it started messing up
Old 08-11-2012, 11:26 AM   #6 (permalink)
turbo-tony's Avatar
Update: I replaced the pump today with a walbro 255. Problem solved! Creamer03 gets an E-high 5 for the correct diagnoses
47LB E3
AGP WGA
Tuned
Old 08-11-2012, 04:48 PM   #7 (permalink)
Creamer03's Avatar
Good deal! Glad i could help!
Old 08-19-2012, 09:50 PM   #8 (permalink)
Member Number: 85489
i have a similar problem with my stage 3 pump and will be installing a walbro 255 to hope it fixes it.did u need a retune after switching the pump?
MOSP Performance is offline   Reply With Quote
Old 08-20-2012, 12:59 AM   #9 (permalink)
Creamer03's Avatar
You should not! Unless your car gets substantially richer you would need one then
Old 08-20-2012, 09:12 AM   #10 (permalink)
Member Number: 31038
This.
My S3 car has never seen a S3 pump. A Walbro 255 has been in there, 4 years later 50k+ no issues.
04 Neon SRT-4
Mopar S3, DSP, 888cc injectors, Dusters tune, Walbro 255 w/ S3 fuel system. NO rewire. e70 397whp/398tq 128k miles
99 Neon Sport Coupe
MPG Daily
2.0 DOHC, 5spd
s3*ps2 is online now   Reply With Quote
Old 02-09-2013, 10:50 AM   #11 (permalink)
baggio10's Avatar
Member Number: 7585
Trying this asap. I have the same issues with my stage 3 setup. I have the original stage 3 pump. Hope this does the trick. Thank you for posting this!!!!
baggio10 is offline   Reply With Quote
Old 02-17-2013, 05:10 PM   #12 (permalink)
redsoxsrt's Avatar
Member Number: 28768
The extended crank is from the check valve In the pump. When it starts to go the line pressure slowly drops over time. So it takes a little while for the pressure to build back up. Try cycling the key a few times after it sits for a while. It should help with the long crank.
Sent from
