Old 11-03-2009, 06:02 PM   #1 (permalink)
Member Number: 48750
Default 750 CC injectors on stock turbo stage 1????
I have come across a great deal for some gently used 750cc injectors I am wondering if i will hurt anything if i put them in an 04 stock turbo w/ stage 1 pcm/ agp wastegate MSD wires. 3"CAI, MPX TBE exhaust w/02 housing. stock fuel set up????
3rd Times the charm... Hopefully
srt4clay is offline   Reply With Quote
Old 11-03-2009, 06:10 PM   #2 (permalink)
Any info helps thanks in advnce.
Old 11-03-2009, 06:11 PM   #3 (permalink)
JoMain's Avatar
Member Number: 73476
whats ur fuel delivry setting like? walbro? pump rewire?
MSD Coil, MM Inserts, Billettech CC, Kinetic WGA, NGK's, Water Leak Mod, Rice Plate
JoMain is offline   Reply With Quote
Old 11-03-2009, 06:19 PM   #4 (permalink)
Sorry it is stock fuel set up....
Old 11-03-2009, 06:21 PM   #5 (permalink)
Member Number: 36585
normal driving and idle will suck!
just-a-neon is offline   Reply With Quote
Old 11-03-2009, 06:27 PM   #6 (permalink)
Should i look into the walbro 255 or what would help me benefit the most from this.
Old 11-03-2009, 06:34 PM   #7 (permalink)
honestly if it were me and you are dead set on installing them, get a dsp then have it rescaled to be able to use the injectors or get a big turbo, or convert to e85...on stock turbo with every single bolt on 750's are too big..
Old 11-03-2009, 07:21 PM   #8 (permalink)
what about stock injectors (stage 1) and i did the rewire on it it seems like that would be a decent way to go to keep a stock set up thats my goal i want mainly a bolt on street driver that i can get into every so often when i am racing my buddys STI or EVO.....
Old 11-03-2009, 07:37 PM   #9 (permalink)
04SRT_08's Avatar
Member Number: 68190
go big turbo and rape evo-slows and slow-burus
'04 SILVER NSRT-4
3" B&B TBE(sold), AGP wga, AEM sri, Crane-Cam plug wires, Stage 1, turboXS rfl on ebay pipe, Boomba mm's, JMB catch can
50 Trim
04SRT_08 is offline   Reply With Quote
Old 11-04-2009, 01:16 PM   #10 (permalink)
Member Number: 76002
Default hai
what is your fuel delivery setting like?
CarsAddict is offline   Reply With Quote
Old 11-04-2009, 01:35 PM   #11 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
It will be like drinking tea from a 55 gallon drum. Way too much injector for a stock turbo & Stage1. Ugghhhhhh
11.9@117 so far.
Wiseman - Just cuz someone else has a fast car with the same parts as you, doesn't mean your car is fast.
Work harder, millions of people on welfare are depending on you.
srt4geezer is offline   Reply With Quote
Old 11-04-2009, 01:37 PM   #12 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (204)
as he said.
WAAAAAAAAAAAYYYYYYYY TTTTTTTTTTTTOOOOOOOOOOOOOOOOOOOOO MMMMMMMMMMMMMMMUUUUUUUUUUUUUUUUUUUCCCCCCCCCCCCCCCC CCCCCCCCHHHHHHHHHHHHHHHHHHHHHHHH FUEL!
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For SoCal guys only! Now offering JD-M Specials!
Old 11-04-2009, 01:38 PM   #13 (permalink)
ticaaal70's Avatar
Member Number: 64715
Trader Rating: (24)
Quote: Originally Posted by mole' View Post
as he said.
Fail
ticaaal70 is offline   Reply With Quote
Old 11-05-2009, 04:18 PM   #14 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
stock turbo and 750's you may run outta fuel try some 1600's
Old 11-08-2009, 11:48 AM   #15 (permalink)
Zero_psi's Avatar
Member Number: 71591
LOL LMFAO get some stage 2 injectors and call it a day
stage 1 with some other goodies
Zero_psi is offline   Reply With Quote
Page generated in 0.15885 seconds with 13 queries
