Alright getting back into my custom fuel system, I am just wondering if 650s will be enough to push a stage 2 50 trim at around 25psi, also running a custom Porsche pump slight gph higher than a walbro with -6 lines. Or go 750s? Also to lazy to search on my iPhone thanks
AGP S256 FS DSP> S3K>PORTING>BUILDING>TUNING contact ptp
I am running a 277 inline porsche pump, if I go with rc's then 38, if I go with DW then around stock 58
DW and RC's are both rated at 3 bar (43.5psi), so why would you keep stock fuel pressure with the DW's? You will be running pig rich if you run them at 58psi base pressure! And I wouldn't recommend running below 40psi for base fuel pressure, you will most likely run into normal driveability issues. I would keep it at 40-43psi at the lowest. But if you want to run that level of boost, you will need 750's. You can run the 650's but will run out of fuel towards the middle-top range, unless you turn the pressure up higher on the fpr (60psi max, I wouldn't push it past that). But your injectors will be running higher duty %, etc. So it is easier to pull fuel than try to compensate for lack of. 750's are the best injector setup for a 50 trim imo
366whp 454tq (going 50 trim)
Stage 2, SST, Built Motor/JMB Race Ported Head, Nitrous, SB Stage 5 Clutch and alot of goodies...
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For all other questions send them to ptperformance@comcast.net For SoCal guys only! Now offering JD-M Specials!
