Old 02-08-2010, 08:49 PM   #1 (permalink)
Chief's Avatar
Member Number: 61336
Default 1:1 rising rate fuel pressure
JUST got my prosport electric fuel pressure on board gauge in today.. did a test drive... i run 25 psi and at idle its around 52 fuel pressure... thinking the 1:1 it would be climbing to around 75-80 psi at wot? BUT NO its only reaching like 65 range? so do the aero fpr only do .5:1 ratio when it comes to hooking the boost line up?
Just wonderin if anyone else has on board fuel pressure gauge and has seen this?
Built
HTA 60
-CoRn EaTEr-
"Shes hunting unsuspecting Evo's and Sti's in their natural environment..."
Chief is offline   Reply With Quote
Old 02-09-2010, 08:07 AM   #2 (permalink)
TurboTime's Avatar
Member Number: 26187
It could be a boost leak, how do you have the vac line to the fpr hooked up??
TurboTime is offline   Reply With Quote
Old 02-09-2010, 09:53 AM   #3 (permalink)
Chief's Avatar
line from turbo to MBC than MBC over to waste gate but right at the waste gate its T'd to the fpr? DO u think since the wastegate only has 15 spring that it has somethign to do with the bleeding off of the pressure? or the mbc? i was told this is how to hook one up?
Built
HTA 60
-CoRn EaTEr-
Old 02-09-2010, 09:55 AM   #4 (permalink)
coors's Avatar
Member Number: 43166
well thats why your mbc is bleeding it off, hook it somewhere else
DEVILSOWN 405-470-4356
any questions pm me
coors is offline   Reply With Quote
Old 02-09-2010, 10:02 AM   #5 (permalink)
Member Number: 28019
^x2
the fpr should be t'd before the mbc. compressor housing>fpr>mbc>wg
mahkis is offline   Reply With Quote
Old 02-09-2010, 11:36 AM   #6 (permalink)
duster360's Avatar
Member Number: 45182
Its probably the MBC bleeding boost but be aware: Low pressure Walbro 255s top out at around 68psi.
A lot of retailers sell the cheap LP version.
TDS is the best choice for ALL your CMR Tuning.
Old 02-09-2010, 01:31 PM   #7 (permalink)
Chief's Avatar
I got a 255 HP MODED pump shes good till 85 psi
BUt YES!!! this is what im thinking too... that the pressure AFTER mbc is NOT real boost OVBIOUSLY because thats its job to bleed the pressure in the line to the wastegate. SOOO i guess i need to T into the line from turbo to mbc... and the line from mbc to wastegate should be a soild line.
BUT i really dont need that kinda fuel lol im already trying to LEAN her out
so may just leave it the way it is, guess it will ALWAYS only push a extra 15 psi or so being hooked up after mbc.
Built
HTA 60
-CoRn EaTEr-
Old 02-09-2010, 01:46 PM   #8 (permalink)
BrandynSRT's Avatar
Member Number: 63412
why didn't you hook it up to the coldside pipe?
BrandynSRT is offline   Reply With Quote
Old 02-09-2010, 01:50 PM   #9 (permalink)
Chief's Avatar
because we dont want the FPR to see vac. even on the charge pipe i do think there would be SOME vac pressure. not as much as AFTER the TB but im sure theres some. the ONLY true boost source is right of the turbo housing.
Built
HTA 60
-CoRn EaTEr-
Old 02-09-2010, 01:59 PM   #10 (permalink)
nutz's Avatar
Member Number: 41700
anything pre TB will be fine, even the biggest turbos will not see vac before the TB, just make sure you have a good BOV (synapse ftw)
I would use a dedicated vacume line for the FPR (not T'd into any thing)
Old 02-09-2010, 02:16 PM   #11 (permalink)
Chief's Avatar
Well maybe ill dedicate a day to do that. Run a line directly from turbo to mbc to waste gate.. than i DO have a nipple that i can add on my charge pipe for the FPR so that would be one solid line. JEZZ more fuel and a month ago i through i needed 044 pump
I always thought charge pipes still saw vac though? the turbo is pullin air in... if u put your hand near or around the intake of the turbo its SUCKIN pretty hard I would think that would cause issues with the FPR?
Built
HTA 60
-CoRn EaTEr-
Old 02-09-2010, 04:17 PM   #12 (permalink)
TurboTime's Avatar
JUST try to run it off the coldside pipe thats how i have mine and it seems to be fine
Old 02-09-2010, 04:18 PM   #13 (permalink)
BrandynSRT's Avatar
im going to run mine of the coldside with a check valve
Old 02-09-2010, 04:24 PM   #14 (permalink)
Chief's Avatar
idk what im gonna do yet, but i gonna do something... i need some vac line though i ran out
Doin billet shift selector tonight FUN fun
Built
HTA 60
-CoRn EaTEr-
Old 02-10-2010, 09:16 AM   #15 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
vac only occurs before the throttle plate
thats why my meth never gets sucked out and its mounted in the charge pipe
Catch me at Sunoco, show me that your loco, put 110 in your 4 doe!!
Project log pics
