Old 08-20-2006, 09:55 PM   #61 (permalink)
selp's Avatar
Member Number: 7528
Trader Rating: (13)
Quote: Originally Posted by jimmortgage
Does the SRT-4 react well to aftermarket cams (as far as check engine lights and not running lean)? Do you get any notable gains with the cams and stock heads?
I put a Crower custom grind in my Dakota and it didn't wake up until I installed larger heads.
if tunned correctly you shouldnt have either of the problems .. 20whp+ is very doable with a good tune again.. youll need to get cam gears to see all the power that you can though, cams will yield some power, but cams are needed if you want to extract all the juice out of them.
selp is offline   Reply With Quote
Old 08-24-2006, 10:30 AM   #62 (permalink)
godfather's Avatar
Member Number: 24924
Trader Rating: (12)
Not really on stock pcm, i always got a missfire code. The ecu kept thinking it was missfiring because it was loping so much. But when i got the stg 1 all the codes went away, so to answer your question NO it does react well on stock ECU but the car ran fine.
Mods:
JE pistons 8:5:1,Eagle rods,Atp GT35 kit,Custom 4" CAI,AGP returnline, Perrin rail,walboro 255,Rc 650's,turboxs b/c,stg1,SAFCII,Devils A/I,MSD wires,Turbonetics upp & bov,JMB HS, Agp charge pipe,iceman 60mm tb,Avid MM,3" Thermal TBE,QW FMIC,TWM sts,ACT stg4 clutch and flywheel,Crower cams & Valvetrain,Fidanza gears. FBM PORTED-stock-intake manifold and head. 412 whp 419 tq
godfather is offline   Reply With Quote
Old 08-26-2006, 11:28 PM   #63 (permalink)
Member Number: 14585
Trader Rating: (19)
Im getting a misfire code with crane 16's as well. A p0300 random misfire.
bigdoggsrt4 is offline   Reply With Quote
Old 08-28-2006, 09:33 PM   #64 (permalink)
all_bran's Avatar
Member Number: 22506
I just got chub listening to that...
Black 2004 SRT4 now gone
Black 2007 SRT8 Charger in garage
all_bran is offline   Reply With Quote
Old 08-18-2007, 07:47 PM   #65 (permalink)
valeriekay_2000's Avatar
Member Number: 27795
Trader Rating: (29)
Watching those vids just makes me more excited to when I get mine built
No more neon...Traded it in for an 08 Civic SI 4dr
valeriekay_2000 is offline   Reply With Quote
Old 08-19-2007, 01:19 PM   #66 (permalink)
godfather's Avatar
Trader Rating: (12)
wow!! I forgot those vids, thanks
Old 08-19-2007, 04:22 PM   #67 (permalink)
Trader Rating: (29)
How is it running now? can you post up a vid of your cutout, an revving it up a little?
Old 08-19-2007, 04:32 PM   #68 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
can't wait to install mine
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 08-19-2007, 05:17 PM   #69 (permalink)
neonmarine's Avatar
Member Number: 21010
Trader Rating: (32)
I just fired up my custom Crowers. They sound alot like that with not timing adjustments and through a Maxxfab JDM no cat!
neonmarine is offline   Reply With Quote
Old 08-20-2007, 01:04 PM   #70 (permalink)
DodgeSRT4SGP's Avatar
Member Number: 9883
Trader Rating: (10)
Can you post a vid of what your car sounds like at idle once you get it tuned and dialed in please?!
11.9@121 420HP/435TQ "Low Boost" (6/24/06: 100+ degree heat and first time on slicks)
100% STOCK Longblock (Old Set Up)
Just know a LOT can change in very little time!
'04 Black w/Sunroof: AEM EMS, Performance CNC Ported Head (www.cncport.com), Crower Stage 3 Cams, ALL Ferrea Valvetrain Components, AGP Turbo Kit and ALL their other goodies (www.agpturbo.com)!
TEAM TOP NOTCH AZ
DodgeSRT4SGP is offline   Reply With Quote
Old 08-20-2007, 03:01 PM   #71 (permalink)
neonmarine's Avatar
Trader Rating: (32)
Sure thing!
Page generated in 0.35392 seconds with 13 queries
