Old 09-17-2009, 12:03 AM   #1 (permalink)
Member Number: 70258
Trader Rating: (12)
Default Valve springs?
Can I reuse the stock retainers with bc springs?
79 Buick Regal 360ci sbc 13.70 @102 n/a so far
97 Trans Am WS6 LT1 11.94 @112.26 n/a with a 1.603 60ft
04 Mustang GT Bolt-ons 13.35 @102.43 n/a more parts soon
04 SRT-4 20g and bolt-ons 13.28@110 with a 2.21 60ft best mph run 13.42@113.5 with a 2.37 60ft on just 20psi
Blackbird1084 is offline   Reply With Quote
Old 09-17-2009, 12:05 AM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
i dont see why not, retainers are needed when reving high. ive used crane springs with stock retainers
AGP S256 FS
Old 09-17-2009, 11:59 AM   #3 (permalink)
Member Number: 41757
You can, modern sells the springs alone. they're around $75, alot better than 250 for more than you need. I saw somewhere on this site that the retainers are good up to 7200 i think. unless you're running an ems, you're limited to the 7000 that most flashers go up to.
Flame Red, 2005, S1, AEM UEGO, SAFCII, turboxs HPBC, 750cc RC injectors, AGP direct fit IC, AGP 50 trim, AGP solid mm and transmission mount, AGP UHP with HKS SSQ, Stainless steel 3in TBE, BC S2 cams, Eibach pro-kit
Brockf98 is offline   Reply With Quote
Old 09-19-2009, 10:37 AM   #4 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
Stock retainers are fine past 7200 by far
Project log pics
Old 09-21-2009, 11:41 AM   #5 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Stock retainers can work well beyond the 7200rpm range but it's about proper valve control at rpm that matters in a competition setting. High lifts, plus the heavy weight of stock cromoly retainers (compared to Ti retainers) make the valve springs have to work harder, and you can get move valve bounce and less valve control. Again, at high rpms. Not to mention reduced wear on the valvetrain.
these are my observations over the years, I would say that if you are running a cam that is ~3.400"lift or higher, and/or running beyond the 7200-7500rpm+ range on a regular basis, Ti retainers and dual valvesprings are the way to go. Also an oil modifier such as Realtune's is a very good option too.
$.02
Form and Function Performance, LLC
Trust those who KNOW performance, not just sell it
Your turbo upgrade/rebuild, airflow, and thermal management specialists!
|612-385-0419| |www.FFPerformance.com| |sales@FFPerformance.com|
a853rox is offline   Reply With Quote
Page generated in 0.13611 seconds with 13 queries
