Old 07-04-2008, 05:41 PM   #1 (permalink)
Member Number: 61479
Default UR cam gear install
couple questions gusy, in the directions that come with the UR cam gears it says the dowell pins in the cams should be 180deg apart from eachoter, when you set everything up. but the stock cam gears have the pins both facing the same way.
do i follow the directions in the UR box, or base it off my stock gears
Fs almost everything! want a car i can drive every day again..
http://www.srtforums.com/forums/f27/...o-more-468832/
smokinazsrt is online now   Reply With Quote
Old 07-07-2008, 01:34 PM   #2 (permalink)
krnlscott's Avatar
Member Number: 25712
Some cams are different and the dowel pins will face different directions. Just make sure the timing marks on the gears are in unison.
krnlscott is online now   Reply With Quote
Page generated in 0.11361 seconds with 11 queries
