Old 07-20-2009, 02:31 PM   #1 (permalink)
Member Number: 71436
Default Ticking sound, need help
At about 2,000 rpms you can hear it the most. a friend of mine said it might be a collapsed lifter, is this correct? what ever it might be what can i do to fix it?
pashen is online now   Reply With Quote
Old 07-20-2009, 02:48 PM   #2 (permalink)
Pureadrenalin9019's Avatar
Member Number: 44393
replace them...I'm currently dealing with it as well, though mine has been gone now for about 4 days.
Make sure your valve springs/rocker arms are tight when you go in there..that could be it too, or possible a bent valve or failing oil pump.
Unfortunately, you'll never get a world-class meal when you start with Spam, and neither will you get a world-class hot hatch when you start with a Caliber.
Pureadrenalin9019 is offline   Reply With Quote
Old 07-20-2009, 03:03 PM   #3 (permalink)
stupid question, but is it an easy job? or do i need to take it to a shop. hopefully i just need to lift the top cover? or do i need special tools.
Old 07-20-2009, 05:38 PM   #4 (permalink)
SwinginACR's Avatar
Member Number: 57527
Trader Rating: (12)
Pretty sure you have to pull the cams to replace the lifters and thats a bitch because of the timing belt. But dont quote me on that, ive not done it and havnt read much on it either.
Pitvipers old car
03' Silver, 50 Trim.....Its gots stuff done 390hp, 390tq on 87 and E85 untuned
05' SRT-4 ACR T-Totaled 2-24-2008
73' Dart Swinger
89' Shelby CSX VNT
SwinginACR is offline   Reply With Quote
Old 07-22-2009, 01:46 PM   #5 (permalink)
sounds like i should just take it to a shop
Old 07-22-2009, 06:41 PM   #6 (permalink)
Member Number: 64745
you have to pull the head to change them. the rocker arms are worn prolly
*black05srt4* is offline   Reply With Quote
Old 07-26-2009, 07:24 PM   #7 (permalink)
brianbr's Avatar
Member Number: 50755
This is a common problem, and there is a tsb for it. The noise is generally caused by the cam caps.
F&F ported ex manifold, ptp wga, 3" O2 housing and downpipe, custom 3" dump, pump rewire, 255 pump, S2 injectors, Dtec, BC stage 3 cams, fidanza gears, ported throttle body, aem cai. agp solid mounts and race fmic, ultimate racing uhp, Hks ssqv, aem wideband, aeroforce scanguage. Hotchkis springs, Prothane Lca's
brianbr is offline   Reply With Quote
Page generated in 0.15866 seconds with 13 queries
