Old 10-08-2009, 02:39 PM   #1 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Default Are the stock head bolts re-usable?
I rember seeing this question a while back, but can't find it, and don't rember if they are. I'm getting ready to finally throw my fully built head on, and curious....either way I may pick up some ARP's, but figured I'd ask first.
Old 10-08-2009, 02:48 PM   #2 (permalink)
hercfe's Avatar
Member Number: 19255
I wouldn't risk it even if they were reusable.
hercfe is offline   Reply With Quote
Old 10-08-2009, 02:49 PM   #3 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
Ya, well I'm probably planning on going with the ARP's, but was just curious.
Old 10-08-2009, 03:00 PM   #4 (permalink)
hercfe's Avatar
I think I read about a few guys re-using them. I just don't trust them enough as it is. If it was just a headgasket, maybe. I am going to put in DCR or ARP when I do my timing belt, H/G, cams, and gears. Unless the car sells first.
Old 10-08-2009, 03:05 PM   #5 (permalink)
tim421165's Avatar
Member Number: 58594
they are re-usable , but you will most likely be doing a headgasket on your car in another 10,000 miles
tim421165 is offline   Reply With Quote
Old 10-08-2009, 03:06 PM   #6 (permalink)
Member Number: 75436
they're totally reuseable if you check the threads for stretch and they pass.
Shocker187 is offline   Reply With Quote
Old 10-08-2009, 03:11 PM   #7 (permalink)
hercfe's Avatar
a thread test on a torque multiplied bolt/fastener is not a true test. Anything torque multiplied or overtorqued intentionally must pass NDI to really be considered safe. like tim said, you'll be doing the h/g in 10000 miles if you don't do it right the first time.
Old 10-08-2009, 03:23 PM   #8 (permalink)
that's why they make stretch gauge, because even torque readings aren't correct if the wrong lube is used. Even common motor oil can throw off reading by 10-15% easy.
checka the threads and if they're money you can reuse.
Old 10-08-2009, 04:38 PM   #9 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
you cannot reuse head bolts, thats just stupid. new ones are less than 20 bucks a set, arp's are cheap too. dont even try it thats just stupid talk
Old 10-08-2009, 04:47 PM   #10 (permalink)
You know nothing, so hurry up and buy. You can reuse them........
Old 10-08-2009, 04:47 PM   #11 (permalink)
blackbird_R/T's Avatar
Member Number: 5369
Sure you can. If you're driving a near stock car and doing the work yourself and they aren't stretched you'll probably be okay. With that said, I wouldn't reuse them since they aren't that expensive. The problem with torque-to-yield bolts is that even if they aren't stretched they may not be able to provide the same clamping force once reused (this is even an issue with new bolts). At stock power levels there usually isn't enough cylinder pressure to cause problems but if you're putting on a built head which insinuates significantly higher power output when combined with other upgrades I'd look into a quality head stud kit or at the very least a new set of OEM bolts.
Old 10-08-2009, 04:55 PM   #12 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
do not waste your time... either get new stock head bolts (like 4 bucks a piece) or get some arp studs.
Pittsburgh Penguins 14-8-0 28 points
Old 10-08-2009, 05:12 PM   #13 (permalink)
tim421165's Avatar
------> x2
Old 10-08-2009, 05:17 PM   #14 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (100)
buy new
bitts is online now   Reply With Quote
Old 10-08-2009, 06:17 PM   #15 (permalink)
Member Number: 42667
The original question of this thread was "Are the stock head bolts re-useable"
And the answer is Yes they are. As long as the threads arnt stretched.
05plsrt4 is offline   Reply With Quote
Page generated in 0.17030 seconds with 13 queries
