Old 05-13-2008, 02:51 PM   #1 (permalink)
Member Number: 63938
Default Spark Plug Oily
Today, when I was changing the spark plugs I noticed that one of the spark plugs was oily. It had oil all over it from the bottom. Other 3 were fine. What could this be? Can you show me where to get the parts needed for this and the guide too please?
I found this guide for changing the gasket:
HOW-TO: Install Valve Cover (aka: Cylinder Head Cover)
Can it be done by myself or do I need to take it to a mechanic? Is it hard to open the engine since the mechanics charge hundreds.
mastdesi is offline   Reply With Quote
Old 05-13-2008, 03:16 PM   #2 (permalink)
1B4dSRT's Avatar
Member Number: 43757
i think it could mean that one of ur piston rings or pistons is f'ed up.
1B4dSRT is offline   Reply With Quote
Old 05-13-2008, 03:27 PM   #3 (permalink)
moparmansrt4's Avatar
Member Number: 50684
Sounds like a bad seal.. There are rubber rings that seal the valve cover around your spark plugs you probably need new ones. VERY easy to change all you need is a deep 8mm socket, a short extension and the new ring seal. and a 10mm socket to take the coil pack off. My sister could do this one, you will have no problem.
Quote: Originally Posted by rollwitstyle View Post
the srt is the worst car to buy it sucks so much balls and tastes like doo doo. buy the t/a they are the fastest cars ever and they taste like steak....... by the way pm me atleast a week in advance if you plan to visit ny
http://www.srtforums.com/forums/f106...ml#post5894846
moparmansrt4 is offline   Reply With Quote
Old 05-13-2008, 03:31 PM   #4 (permalink)
Member Number: 5369
If there is oil in the spark plug cavity and on the threads that's usually a good sign one of the valve cover gasket seals that goes around the spark plug hole is leaking. You want to get that corrected and also clean that area out. If you leave oil residue down there it makes it easier for carbon tracking problems to develop. If the electrodes and ceramic that's exposed to the combustion chamber is soaked and has burnt on oil I'd be a little more concerned you're leaking oil past a piston ring or valve seal which is getting burnt in the combustion chamber.
You might want to do a compression and leak down test and if that comes back good replace the valve cover gasket for that plug, swap in a new set of plugs (ensuring the head is clean) and check them periodically to see if the problem returns. Also pay attention to the exhaust to see if you're smoking any. It might be easier to spot this if you have someone follow behind you as you first start the car cold, cruise then accelerate briskly, etc. (it can sometimes be easier for the trailing car to spot during night with headlights on).
Old 05-14-2008, 07:02 PM   #5 (permalink)
i went to the mechanic and he set you need a whole gasket set which is 75$ plus 40$ labour... I am sure only the rubber things (valve cover gasket seals) needs to be replaces and not the whole thing since only 1 spark plus was oily... now i searched on ebay they sell full kits, where can i get just the vavle cover gasket seals. thanks.
Old 05-14-2008, 07:37 PM   #6 (permalink)
Member Number: 18856
your local auto parts store should have a valve cover gasket set. seeing how your in canada i don't know what stores are up there. you could always order online from advance auto parts or autozone
if not try one of the vendors like mopar performance
obtw dont forget RTV for the corners of the valve cover gasket
not a thing just another slow ass neon
joe smalls is offline   Reply With Quote
Old 05-14-2008, 07:58 PM   #7 (permalink)
Yeah I would never pay a mechanic to do this. It is sooooo easy.
Old 05-14-2008, 09:30 PM   #8 (permalink)
do i really need rtv for a neon? can you tell me exactly where to put it?
Old 05-15-2008, 02:10 PM   #9 (permalink)
i put it on all the corners and edges.
four corners
on each side of cam sensor
grey high temp RTV
this is just a suggestion
have my head off right now and i know i will be putting rtv on the valve cover gasket.
Page generated in 0.17145 seconds with 11 queries
