Old 10-13-2009, 11:04 AM   #1 (permalink)
BigBird03's Avatar
Member Number: 60153
Trader Rating: (42)
Default So...I broke a cam cap bolt into the head. Doh.
What should i do, what can i do? help me i dont want to replace the head because of this lol
drill it, try an easy out?
drill it out, try and rethread it and hope it doesnt crack?
Put the one bolt on the other side of it in and hope to god it doesnt break?
Its one of the center ones.
idk. help plz and thanks.
BigBird03 is offline   Reply With Quote
Old 10-13-2009, 05:12 PM   #2 (permalink)
BigBird03's Avatar
Trader Rating: (42)
ttt
Old 10-13-2009, 05:15 PM   #3 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
if you can get vice grips on it just turn it out, if its broke in the head get an extractor, if its seized drill it out and try a heli coil
Old 10-13-2009, 05:21 PM   #4 (permalink)
BigBird03's Avatar
Trader Rating: (42)
Yeah its broken into it where its sitting flush with the head. extractor? Where can i haz this from?
Old 10-13-2009, 05:24 PM   #5 (permalink)
nutz's Avatar
Trader Rating: (19)
they have em at sears, pepboys ...almost any hardware place
you drill a little hole in the top then use a reverse tapping bit to grab it the walla its out (hopefully )
Old 10-13-2009, 05:28 PM   #6 (permalink)
GsXr1000bIlL's Avatar
Member Number: 51557
Default ....
i broke one when I had my srt and put my crane 14s in, drove it like that for around 20000 miles with no issues at all, had a mechanic quote me 50 bucks to pull the valve cover off and drill it out for me... hope this helps
AGP Wastegate Actuator
TurboXS MBC
AGP 3inch CAI
Greddy RS BOV
AGP BOP
AGP Hardpipe Kit
MSD Ignition Coil and MSD Spark Plug Wires
NGK Iridiums
AGP Dogbone Motor Mounts
AGP Transmission Mount
MPX 3inch Turboback
Bwoody FMIC
Perrin STS
Booger Bushings
AGP Oil Can
Greddy TT
LFS 60mm TB and Adapter
Blue LED's: Instrument, HVAC, Boost
Silverstars
180* Thermostat
Crane 14s
Crane Valve Springs & Retainers
Fidanza Cam Gears
GsXr1000bIlL is offline   Reply With Quote
Old 10-13-2009, 05:40 PM   #7 (permalink)
BigBird03's Avatar
Trader Rating: (42)
ftw, Fuck it then im not fixing it. Not yet atleast. I just got it back together and all is good, Ill take it apart next week or something. I got the drill bit and easy-out though, If thats what you were talking about little nutz. lol
Old 10-13-2009, 05:42 PM   #8 (permalink)
CJsStocker's Avatar
Member Number: 58783
Trader Rating: (40)
buy my head.
CJsStocker is online now   Reply With Quote
Old 10-13-2009, 06:44 PM   #9 (permalink)
BigBird03's Avatar
Trader Rating: (42)
Fuck your head! I have another head thats actually ported and shit, I really just dont want to swap it right now. I need the money for other things
Old 10-13-2009, 06:49 PM   #10 (permalink)
CJsStocker's Avatar
Trader Rating: (40)
swapping a head isnt that big of a deal.
Old 10-13-2009, 07:02 PM   #11 (permalink)
BigBird03's Avatar
Trader Rating: (42)
I didnt say it was, I just dont want to buy a 5 layer headgasket and arp studs right now.
Old 10-13-2009, 07:13 PM   #12 (permalink)
Floner's Avatar
Member Number: 26683
Um drilling it out and using an easy out would take you maybe 10 minutes. Jussayin.
This Place For Rent!
Floner is offline   Reply With Quote
Old 10-13-2009, 07:19 PM   #13 (permalink)
BigBird03's Avatar
Trader Rating: (42)
Um I was a little nervous about drilling it after a few people told me if i mess it up at all that the head would be trash. I already got a drill bit and easy out to do it, but was second guessing doing it when a few people told me not to.
Old 10-13-2009, 07:26 PM   #14 (permalink)
nutz's Avatar
Trader Rating: (19)
naa if you fuk it up you still got a heli coil
Old 10-13-2009, 07:34 PM   #15 (permalink)
Floner's Avatar
Its not hard just keep a steady hand, take the cap off, then get a punch, center it on the bolt you wish to extract. Give it one solid hit with a mallet this will give you a point so your bit wont be all over the place and allow you to drill straight. When you start to drill make sure you tape off the areas around it so you dont get shaving down into the nooks and crannies of your head.( I have found keeping a shop vac running with the nozzle next to the drill works wonders in sucking up the loose debris. Also I would recommend not using a drill bit no more then 1/2 the bolt diameter. Now drill about a 1/2-3/4" down the center of the bolt. Now make sure when you use your easy out, that it goes down far enough to catch hold. Also it is a good idea to also give it a solid hit with a mallet before you try wrenching it, and voila the bolt should come out. If it feels like it is hard to get out that means the bolt has a possibility of being crossthreaded, don't fret, just take your time and slowly work it back and forth till it comes out. You will need to retap the hole before you install the new bolt. Trust me I have extracted much more difficult bolts than cam cap bolts, this is cake.
Page generated in 0.19750 seconds with 13 queries
