Old 04-13-2008, 09:28 AM   #1 (permalink)
quickshift's Avatar
Member Number: 55168
Trader Rating: (29)
Default Quick Timing ????? Pics Inside!!!!!!!
just want a couple other opinions before i put this shit back together. this is where the TDC on the cam sprockets are:
when the TDC on the crank is here:
i know its suppose to be 1/2 tooth off just not exactly sure which direction?? does it look right??
BEST ET: 12.68@110 stg 0, stock turbo, stock intercooler, pump gas, & no meth
MODS ADDED SINCE THIS RUN: AGP BB .50T with all supporting mods
quickshift is offline   Reply With Quote
Old 04-13-2008, 09:41 AM   #2 (permalink)
quickshift's Avatar
Trader Rating: (29)
Old 04-13-2008, 10:04 AM   #3 (permalink)
josB_srt4's Avatar
Member Number: 41596
Trader Rating: (19)
its off...
josB_srt4 is offline   Reply With Quote
Old 04-13-2008, 10:06 AM   #4 (permalink)
OrAnGe-SrT4's Avatar
Member Number: 29828
Trader Rating: (17)
The exhaust cam gear, or the furthest to the firewall, should be 1/2" below the intake cam gear.
Local AEM EMS tuning DFW area. PM for details.
OrAnGe-SrT4 is offline   Reply With Quote
Old 04-13-2008, 10:06 AM   #5 (permalink)
quickshift's Avatar
Trader Rating: (29)
so its suppose to be a half tooth off the other direction?? the tensioner already tight in that pic BTW
Old 04-13-2008, 10:08 AM   #6 (permalink)
quickshift's Avatar
Trader Rating: (29)
sweet thanks man
Old 04-13-2008, 10:11 AM   #7 (permalink)
Trader Rating: (17)
No your timing belt is on and the tensioner is set so your good. BEFORE you put the belt on it's supposed to be a half inch off so it'll straighten up when you slide the belt on.
Now the tensioner is funky to set imo, just make sure you have the pin in the center when you tighten the bolt down. And once it's tight check again because I had mine move around when I'd go to tighten the bolt down.
I think you're then supposed to rotate the oil pump sprocket two full revolutions then check again. Long ass process if you ask me.
Old 04-13-2008, 10:42 AM   #8 (permalink)
quickshift's Avatar
Trader Rating: (29)
so it was correct?? i went out there and messed with it somemore
Old 04-13-2008, 10:45 AM   #9 (permalink)
quickshift's Avatar
Trader Rating: (29)
here is what i have now..... tensioner is tight, crank tdc is right on:
Old 04-13-2008, 10:51 AM   #10 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (17)
I always thought exhaust was 1/2 inch behind intake. That looks 1/2 inch ahead to me. I haven't done this yet but I'd like to be sure.
HCCAFan is offline   Reply With Quote
Old 04-13-2008, 10:53 AM   #11 (permalink)
quickshift's Avatar
Trader Rating: (29)
i though 1/2 tooth, not 1/2"...........now im confused again
Old 04-13-2008, 10:55 AM   #12 (permalink)
quickshift's Avatar
Trader Rating: (29)
where you at ORANGESRT4????? i need some input so i can hurry and drive my car!!! i driven it 3 days in the past month!
Old 04-13-2008, 11:06 AM   #13 (permalink)
Member Number: 42667
With the belt on, tensioner adjusted correctly, rotate the crank twice, line the crank to the trailing edge of the tooth (which you have in the pic) take a peice of paper and like it up accross all 4 timing marks on the cams. The center 2 will be up a hair off the peice of paper.
That is the best way to know if its in time.
05plsrt4 is offline   Reply With Quote
Old 04-13-2008, 11:10 AM   #14 (permalink)
quickshift's Avatar
Trader Rating: (29)
k lemme go try that shit real quick!
Old 04-13-2008, 11:12 AM   #15 (permalink)
HCCAFan's Avatar
Trader Rating: (17)
Nevermind. I just looked it up on alldata and yours looks perfect.
They say;
"Set camshafts timing marks so that the exhaust camshaft sprocket is a 1/2 notch below the intake camshaft sprocket (Fig. 137). CAUTION: Ensure that the arrows on both camshaft sprockets are facing up."
Page generated in 0.29494 seconds with 11 queries
