Old 05-11-2008, 09:28 PM   #1 (permalink)
Member Number: 18856
Default quick comp bc 2,3 crane 14
Street/Strip Specification BC 2
Street/Strip Specification Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK.
ADV. dur Dur@.050 Max Lift
232 / 232 186 / 184 .416 / .410
Race Specification BC 3
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0160.
272°/272° 194°/186° .389"/.383"
CRANE 14's
Advertised Duration Intake/Exhaust 246 / 238
Duration @ .050 Intake/Exhaust 204/196
Lobe Separation 110
Gross Lift 364/345
Crane 16's
Advertised Duration Intake/Exhaust 250 / 250
Duration @ .050 Intake/Exhaust 208/208
Lobe Separation 110
Gross Lift 374/374
Crane 18's
Advertised Duration Intake/Exhaust 258 / 258
Duration @ .050 Intake/Exhaust 216/216
Lobe Separation 112
Gross Lift 394/394
this is what i could find on crower 2's
Adv dur dur@/050 gross lift with 1.75
238 / 236 187 / 184 .409" / .403"
tell me if i am wrong but it looks like the 14 would sit in between the BC 2 and 3
not a thing just another slow ass neon
joe smalls is offline   Reply With Quote
Old 05-11-2008, 09:32 PM   #2 (permalink)
Member Number: 63959
264°/264° 186°/184° .350"/.310"
CRANE 14's
Lobe Separation 110
Gross Lift 364/345
the crane duration rating is actually at 1mm, and not .05.
which causes for a misleading comparison because then the results are skewed since bc's are rated at .050
between those cams, they all have 3 different "ideal situations"
bc2 - good street cam for all around power
14 - spool the turbo up quicker. proven ~300rpm spool gain. wont make power that you need it to as you get near/past 6k
bc3 - top end, while still retaining some streetability.
Drastic._ is offline   Reply With Quote
Old 05-12-2008, 10:34 AM   #3 (permalink)
Nyt-RyDa's Avatar
Member Number: 14618
Trader Rating: (67)
Cool that helps out... now add the crane 16s and crower 2s into the mix
>Mods<
AGP 6oTRiM ||PnP head || BC stage2 cams w/springs&retainers|| ported intake mani/ pTP 55mmtb || TiALwga7psi||AEMcai||Coolingmist w/i||DW750ccinject0rs||QW FM!C || stageONE pcm ||AEMuego||DCRoil mod||AGPdogbones||AGPuppipe w/HKSssq||BW tractionBARS||DtecFC+BC ||AGPreturnline||Needswing Ecutout||||wotBOX||ACT streetDISC clutch||BORLAexhaust||
______________
SMOKING BAD!
Nyt-RyDa is offline   Reply With Quote
Old 05-12-2008, 11:13 AM   #4 (permalink)
crower s2- too large of duration/lift combination to actually take advantage of for your powerband/rev limit.
id personally just rock 16s and be done w/ it.
Old 05-13-2008, 09:23 PM   #5 (permalink)
added crower 2's and the rest of cranes line
Old 05-13-2008, 10:03 PM   #6 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
You forgot
CRANE 12's
Advertised Duration Intake/Exhaust 246 / 246
Duration @ .050 Intake/Exhaust 204/204
Lobe Separation 108
Gross Lift 364/364
Project log pics
Old 05-15-2008, 07:35 AM   #7 (permalink)
The SRT'N 1's Avatar
Member Number: 36207
Trader Rating: (17)
Which one is a better cam crane 18 or brian crower stage 3??? just got rid of my crane 16s as i wanted something bigger for top end since i will be reving past 7200rpm..??
DCR oil system, manley rods, DCR 8:5:1 custom dish .40, CNC ported head, compet. valve job, +1mm exhaust/intake valves, Knife cut crank, O-ringed block/Head, Crane 20s, DCR Spring/retainers/hydraulic Lifters, Fidanza gears, CTI tubular manifold, tial 44mm, AEM EMS, 1450cc injectors, Dual Modified high flow 255 walbros, bottleneck fix, agp fuel return kit, GT3582R, And da JUG...NX Direct port 100-250 shot...etc...700whp or bust
The SRT'N 1 is offline   Reply With Quote
Old 05-15-2008, 02:05 PM   #8 (permalink)
from the numbers it looks like crane 18's
Old 05-19-2008, 06:13 PM   #9 (permalink)
03ACR's Avatar
Member Number: 59357
what works the best with the mopar stage 3 (w/ toys) BC2's or crane 16's or what do you guys think every day driver but race on the weekends ....
what do you think???????
2003 E-blue srt-4 Stg3r w/toys// clutch masters stg4//dss axles// xs BFMIC// hard pipes// 62mm Tb// mopar catback// mopar STS//
personal best ET- 12.3 @ 113.4
personal best MPH- 115
-1980 dodge pick-up 4x4 on 44" w/ 671 blowen 426ci
03ACR is offline   Reply With Quote
Old 05-19-2008, 06:36 PM   #10 (permalink)
Member Number: 64119
those crower stg2 specs are wrong...
Santiago. is offline   Reply With Quote
Old 05-21-2008, 07:11 PM   #11 (permalink)
thats all i could find. let me know of the correct thanks
Page generated in 0.30029 seconds with 11 queries
