Hey y'all,
So, last night I was doing a bit of tuning on a customer's vehicle and immediately ran into some strange issues. This customer has a nicely built motor, built bottom end, ported headed, over sized valves, REV springs, Crower (Not BC) stage 2 cams, adjustable cam gears, a bunch of other goodies. Not a bad little setup...
Here's the problem... The engine idle is extremely poor, it runs excessively rich for the fuel system setup that is installed, and strangest of all manifold pressure at idle is 60 KPa
(approximately -6.5 in/Hg on a relative pressure gauge at our altitude). I have never seen an engine idle with manifold pressure this high. This is literally half the vacuum pressure it should be...
What are your thoughts on this? I really feel like there may be a significant cam timing issue here. I know the cams were set using a DCR cam fixture but obviously that doesn't mean that overall cam timing is correct.
Any help would be appreciated!
Thanks in advance guys!
