see because when i set timing i use just the cams, the arrow on the crank/ oil pump housing and the lobes of the cams in the #1 piston. along with the lines on the gears them self. i have not used a dial indicator and a degree wheel to determine true TDC. i know the DCR setting fixture helps put the cams in true tdc, but with out that tool just using the dial indicator and a degree wheel is it more accurate than just using your 'eyes'?
My cams are already installed and the engine is in the car. I have it lined up and running good by just lining up the marks on the crank/oil pump housing, and the lines on the cam gears, but I think I could do better than just eyeing it up.
So since its in the car already a degree wheel is out, so my next choices are piston stop or dial indicator. I will probably use a cam setting fixture as well.
by dwell he didnt mean in the aem, he meant the ammount of time the piston stays at tdc it has a winder where it is neither coming up or down and that is called dwell time.
