Old 03-16-2008, 03:25 PM   #1 (permalink)
Member Number: 61497
Default oil problem
i have a 05 srt4 and my car goes though a qrt to qrt and a half of oil in two to three day. it has a brand new turbo on it that is stock. so what could be the problem.
silverdodgesrt4 is offline   Reply With Quote
Old 03-16-2008, 03:50 PM   #2 (permalink)
RedSRT4Me's Avatar
Member Number: 402
Take it to a mechanic. 2 quarts don't just disappear. You'd have to be creating a smoke screen bigger than batman not to notice where your oil is going.
RedSRT4Me is offline   Reply With Quote
Old 03-17-2008, 05:02 AM   #3 (permalink)
no ever sence they put the new turbo on it has not smoked at tall. but alot of carbon it coming out or at less i this its carbon on the back or may car
Old 03-17-2008, 05:53 AM   #4 (permalink)
ojedel01's Avatar
Member Number: 34290
Post
Like he said, if you are burning it you must have a huge smoke screen out back when you drive. That much oil disappering is just plain wrong . If it is leaking on the engine you should smell it burning. The only other thing I can think of is that you are sucking a ton of oil into your throttle body through the PCV system. Take your cold side pipe off the intercooler and see if it is filled with oil. If not, check to see if you have a puddle of oil on the ground after parking it.
ojedel01 is offline   Reply With Quote
Old 03-17-2008, 06:18 AM   #5 (permalink)
dj2
dj2's Avatar
Member Number: 28474
Trader Rating: (28)
yeah, sounds like blow-by getting sucked into the intake, (this happened to me right before the motor blew)
you probably have cracks in the ring lands and oil is getting blown through the pcv and breather on the valve cover. My catchcan filled up quickly and the filter I had on the breather was soaked in oil.
dj2 is online now   Reply With Quote
Old 03-17-2008, 07:41 AM   #6 (permalink)
Member Number: 53871
either everything stated above so far.. or its the piston rings.. i kno because my motor is getting replaced now because of a similar situation...
Sound good?!
03' stock turbo
needswings dp v5 (non-fouler)
ngk 4306 (.35 gap)
8.5mm wires
Jmb hardpipes and hks bov
srt4baby is offline   Reply With Quote
Old 03-19-2008, 04:47 PM   #7 (permalink)
yea i know but how much boost are yall puting to it with what yall got. i just got a stock turbo and thats it really a stock car and the motor is going and every one has aftermarket on there cars and they run longer then mine whats up with that. please explane
Old 03-19-2008, 09:54 PM   #8 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
what kinda gas do you run? how often do you change and what type of oil do you use?
Catch me at Sunoco, show me that your loco, put 110 in your 4 doe!!
Project log pics
Old 03-20-2008, 05:02 AM   #9 (permalink)
i run 93oc. and i haven't put full synthetice in yet but im runing in it 10w 30 the car was asking up when i got it.
