Old 12-19-2005, 03:36 PM   #1 (permalink)
Member Number: 4274
Default INFO: Head Bolt Torque #'s and Pattern
Quote: Originally Posted by snetphilie
The cam removal and installation guide covers most of the details that are required for doing a complete head removal and installation but I need just a few more details. Here's what I need:
Head bolt torque pattern (pounds, pattern, and final x degree turn etc)
Intake manifold torque specs
Exhaust manifold torque specs
Three Dealerships have given me the run-around and won't tell me the specs so hopefully somebody here will help me out. I have the head on and ready for torqing so the sooner the better.
THANX A MILLION!
See below for the torque information. A detailed head removal/installation supplement to the camshaft removal/installation sticky will be added in the near future. I'm too busy actually doing a head removal/installation to do the write up on it this week but I will get to it soon (along with pictures for this and the tips below. For now, here are the spec along with a few pointers.
Quote: Originally Posted by Shifty
Head:
First: All to 34 N·m (25 ft. lbs.)
Second: All to 82 N·m (60 ft. lbs.)
Third: All to 82 N·m (60 ft. lbs.)
CAUTION: Do not use a torque wrench for the Fourth step.
Fourth: Turn all bolts an additional 1/4 Turn
Exhuast Manifold:
Gradually tighten fasteners, starting at center and progressing outward in both directions to 28 N·m (250 in. lbs.)
Intake Manifold:
No senquence Install intake manifold. Tighten fasteners to 23 N·m (200 in. lbs.).
- Turbo/Manifold Removal Tip: If you plan on removing the turbo/manifold (ie. you aren't going to take the shortcut and just unbolt it from the head) you might want to remove the axles, alternator, and oil filter adapter first. You can also unbolt the power steering fluid cooler and push it off to the side. This will make it much easier to get at all those nicely heat treated and rusted bolts holding everything together. This also provides a good opportunity to change the transmission fluid. NOTE: If you aren't going to change the tranny fluid, you can still remove the axles, but you will want to buy special plugs that you can push into the differential to stop all the fluid from coming out. Its a bit messy but if you're quick you can keep most of your fluid in. (Lisle part # 23400 is a set of these plugs of all different sizes)
- Crank Pulley Removal Tip: All you need is a 3 jaw puller and a bolt. First, remove the bolt holding the crank pulley in place (you will want to use an impact wrench to do this). Then, you will want to place a bolt slightly smaller then the crank pulley bolt, and long enough to bottom out and still stick out an inch, in the hole where the crank pulley bolt was (I will post the best length to use once I get around to measuring the one I have at home). To make it easier, you can also take a drill to the head of the bolt and make a small notch in the center so the puller stays centered on the bolt. Place the jaws of the puller through the holes in the pulley, having it grab onto the center section of the pulley (Most large pullers will not fit so make sure you have a medium to small sized puller for this to work). If you place the jaws on the outside edge of the pulley, it will bend the pulley, which is bad. Tighten the bolt on the puller, lining it up with the bolt you have placed in the crank pulley bolt hole. As you tighten the puller bolt, it will slowly pull the crank pulley off of the crankshaft. If you have the perfect sized bolt, and made a notch in the top, hold onto it, as it may come in handy the next time you feel like ripping your motor apart.
- Camshaft Removal Tip: If you have everything taken apart, you don't need to jack the engine up in order to slide the camshafts out as long as you don't mind getting rid of part of your timing belt cover. All you have to do is cut 4 straight lines from the camshafts straight to the top of the cover, making two slots in the cover that allow you to pull the camshafts straight up and off of the head. You can remove as much or as little of the cover as possible, however, making two very narrow slots, just big enough to fit the cams through, will allow you to maintain as much protection for your timing belt as possible. I personally prefer usign a dremel type tool with a soft metal polishing disc as this will still cut through plastic but wont damage the surrounding parts too much if you happen to get a little too excited.
- General Tip: If this is the first time you're taking your car apart and you're worried about doing something wrong, use these tips to help make things go smoother. First, grab a roll of masking tape and a permanent marker. Every time you take something apart that you might get confused about later, write a note on some masking tape that will remind you how to put it back together, and attatch it directly to the part (for example - into sensor on top of intake manifold). Next, grab a large piece of cardboard. Every time you take a bolt off, stick it through the cardboard and write a note on the cardboard next to it reminding you where it goes. This tip works well, even for us veterans, so that we don't misplace a bolt, although we might not need the note next to it reminding us where it goes.
Under Const: 03 Black w/ Viper seats
Prfrmnc: '04 Injctrs, ECU, & LSD, Cust 3" Mndrl Al Int w K&N, Cst Brthr Sys, Mpr BOV Cnv, Frg WGA, Prthne MM Insrts, MPX UDP, MPX Coil Heat Shld, DC Sprts F&R Strt Brcs, Stck Styl Plshd Al Shft Knb, Konig 16x7 Flt Blck Glides, cst battery relocate, & FI CF Hood.
Blng: Mpr Stnlss Stp & Door Edge Grds & Raingrds & Blu Neon lighting under car, driver & pass foot wells, driver & pass seats, & the 4 main vents
snetphilie is offline   Reply With Quote
Old 12-19-2005, 03:47 PM   #2 (permalink)
Shifty's Avatar
Member Number: 19343
Trader Rating: (67)
Default Head
Tuned By Tony Palo
Some Vendors make claims of there parts holding or making XXXwhp. I say prove it
Shifty is offline   Reply With Quote
Old 12-19-2005, 03:49 PM   #3 (permalink)
Shifty's Avatar
Trader Rating: (67)
Default Exhaust manifold
Old 12-19-2005, 03:49 PM   #4 (permalink)
thispainisourz's Avatar
Member Number: 21668
Trader Rating: (23)
jesus , it took you what 5 minutes to dig that up and post it , beat me to it
thispainisourz is offline   Reply With Quote
Old 12-19-2005, 03:50 PM   #5 (permalink)
Shifty's Avatar
Trader Rating: (67)
Default Intake manifold
no senquence Install intake manifold. Tighten fasteners to 23 N·m (200 in. lbs.).
Old 12-19-2005, 04:03 PM   #6 (permalink)
Shifty's Avatar
Trader Rating: (67)
Quote: Originally Posted by thispainisourz
jesus , it took you what 5 minutes to dig that up and post it , be me to it
damm 5 mins , it would have been sooner but , I had to finish my Sandwich
Old 12-19-2005, 04:12 PM   #7 (permalink)
Member Number: 4274
WOW!!! What are you, a shop manager or somethin? (and if so, did you blow off a customer for 5 minutes while you looked this up ROFL) I'll call up my friends in Denham Springs to drive over to your place and shake your hand for me
Note to all... I might just take some time this week to do a writeup on head removal/installation. I might even throw in some information on porting and polishing!!!
Well... now I gotta finish putting my baby back together. I took her apart after 72,000 miles of way too much city traffic and way too little WOT. Mobil 1 and Royal Purple have left the head components and cylinder walls looking new (no oil buildup or anything anywhere!). Not having a catch can, however, has left the throttle body, intake mani, and chamber quite dirty however. I took it apart just to clean and inspect and now I will be putting it back together with the addition of a catch can, custom CAI, UDP, and Forge WGA. WISH ME LUCK!
Old 12-19-2005, 04:54 PM   #8 (permalink)
Nasty_NAS's Avatar
Member Number: 11197
I wanna know who in the world got a torque wrench on the exhaust mani??
Agp dbb 50, Agp race fmic, Agp lhp, Dtec,
rc 750s, Crane fire wires, screamin demon coil,
jmb uhp & 3" cai, Tial bov, Twm sts w/stainless knob, DC strut tower bar, Injen turboback
Lca Bushings w/ Rage Delrine, Cooling Mist stage 2
Inovative wideband w/xd-16 guage, Greddy TT
Stewart Warner guages (Boost, EGT & Oil Pressure)
Blue guages w/red line, Megan coilovers, Dcr Bottom end, dcr head comming soon
Nasty_NAS is offline   Reply With Quote
Old 12-19-2005, 05:18 PM   #9 (permalink)
Shifty's Avatar
Trader Rating: (67)
Just ur friendly neighborhood , ASE Ceritified Master Tech , and DCX Automotive Technician . shhh tell no one ! I heard some of the locals on the board want to burn us alive . So now i must run and hide .
Old 05-22-2006, 01:05 AM   #10 (permalink)
blew x u's Avatar
Member Number: 34069
Trader Rating: (60)
Anyone who put the manifold on the head and the installed the head.
471hp 521tq street tune best et 11.4 @ 128 1.906 60ft. "BONE STOCK" fast women and hot cars yeahhhh!!!
blew x u is offline   Reply With Quote
Old 09-24-2006, 10:11 AM   #11 (permalink)
MikeD's Avatar
Member Number: 2830
Trader Rating: (60)
I know this thread is old as hell, but I was just installing my head on my motor, and my FSM says to tighten the head bolts to 50ft. lbs., not 60.
|DCR Pistons| |DCR Rods| |OE crank| |DCR bearings| |DasMotorsports head| |Crower springs| |Crane 16 cams| | UR Cam gears | |AGP turbo manifold/Psi-Fi turbo| |Psi-Fi intercooler| |JMB CAI| |JMB ported intake manifold| |LFS 60mm TB| |NX wet kit, etc., etc.|
Should be 13's, for sure
Yours for the right price! (Cheaper then you think!)
MikeD is offline   Reply With Quote
Old 09-29-2006, 09:53 PM   #12 (permalink)
dave09092's Avatar
Member Number: 43829
Trader Rating: (20)
Hey MikeD.... did you find your answer? Is the head bolt torque 50ft lbs or 60ft lbs? Have a great day!
dave09092 is offline   Reply With Quote
Old 09-30-2006, 03:42 PM   #13 (permalink)
MikeD's Avatar
Member Number: 2830
Trader Rating: (60)
I have no idea, I never found an acceptable answer to my question, however, per DCR headgasket instructions, it was torqued to 85ftlbs
Old 10-02-2006, 09:40 PM   #14 (permalink)
dave09092's Avatar
Trader Rating: (20)
Hey Mike... I purchased the original srt 4 factory service manual and it says #1 25ftlbs, #2 50ftlbs, #3 50ftlbs, #4 1/4 turn. I hope this helps.
Best Regards,
Dave
Old 10-13-2006, 10:52 PM   #15 (permalink)
Member Number: 40951
Best Regards,
Dave
Dealerconnect calls for step 2 and 3 to be 60ftlbs?!?
srted4ever is offline   Reply With Quote
Page generated in 0.23769 seconds with 13 queries
