Old 10-02-2009, 06:20 PM   #61 (permalink)
SY04SRT4's Avatar
Member Number: 3903
Exactly...Its going to go to a Y or T adapter, dunno which yet. I am also going to use a gauge fitting somewhere to temporarily tap a spare vacuum gauge on there and see what it's pulling.
2004 SRT-4 BEE-OTCH!! <<Under Construction>>
AGP Delta 55, FIC 1150's, Magnafuel 625 etc...
SY04SRT4 is offline   Reply With Quote
Old 10-02-2009, 06:23 PM   #62 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
nice. are those -10an fittings on the valve cover?
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 10-02-2009, 06:26 PM   #63 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
hey somebody is looking for a tuner in norcal
AGP S256 FS
lyncoo is online now   Reply With Quote
Old 10-02-2009, 06:35 PM   #64 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
thanks for the heads up.
people know where to find me
Old 10-02-2009, 06:36 PM   #65 (permalink)
lyncoo's Avatar
Trader Rating: (92)
he posted in the cali section
Old 10-02-2009, 07:36 PM   #66 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (73)
Default Paint time...
So i mocked up what i think your doing and what i plan to do...
You:
Valve cover Pass side and Valve cover Driver side meet in a Y block, then go to the exhaust. Intake manifold is capped off?
Me:
Valve cover Pass side and Valve cover Driver side meet in a Y block, then go to the exhaust. Oil return on turbo is sent to an fitting on oil pan. Then old oil return to block sends oil through -12 fitting to catch can that connects Intake manifold...
Is this correct?
supermech21 is online now   Reply With Quote
Old 10-02-2009, 08:14 PM   #67 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
keep this thread hot guys, best thing since sliced bread
Old 10-02-2009, 08:30 PM   #68 (permalink)
Member Number: 62827
subscribed!!
spoolinbee is offline   Reply With Quote
Old 10-02-2009, 08:34 PM   #69 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
You:
Me:
Is this correct?
my head hurts
Old 10-02-2009, 08:38 PM   #70 (permalink)
nutz's Avatar
Trader Rating: (19)
why go to the block?
Old 10-02-2009, 08:41 PM   #71 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
x2.
just run a y or t to the im port to catch can,
then from catch can to y block on the passanger side,
from the y block to the ex. system
Old 10-02-2009, 08:58 PM   #72 (permalink)
nutz's Avatar
Trader Rating: (19)
thank you soo much for being a pioneer and trying this, I know a few of us here have wanted to try it for a longggg time if this works it will be an absolute must have for everyone (top of the list for power guys)
Old 10-02-2009, 09:00 PM   #73 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
we should start putting together a parts list an How to
Old 10-02-2009, 09:33 PM   #74 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Me:
Is this correct?
Not exactly as you laid it out. The exhaust side is fine, although I am not really a fan of them, it will help out immensely with the pressure issues. It has been my experience that you can sometimes get the crank to '0' pressure, but rarely no additional vacuum. Also the exhaust bung needs to be at the correct angle for best efficiency.
Now the only real issue I see is you have hooked up your old return line as a vacuum venting point, but hooked up the end to the intake which will end up pressurizing your crank not to mention kill some power. I would ideally run that line from the oil return, to a catch can (not a $20 one either) then to your CAI, not the intake mani itself. That way you will always have active VACUUM on the line. Now I have not done all the testing yet to make sure that the vacuum is not too great as excessive crankcase vacuum can cause issues with the rings, but I would think a -10AN return under vacuum from the CAI would be fine.
Make sense?
Because a) it's already a fitting you can utilize and b) it is direct relief of crank pressure instead of snaking through the block and head
A good catch can is a must, but as described above, if you run one line to the block, and the other to the intake, you will be pressurizing the crank with boost.
Form and Function Performance, LLC
Trust those who KNOW performance, not just sell it
Your turbo upgrade/rebuild, airflow, and thermal management specialists!
|612-385-0419| |www.FFPerformance.com| |sales@FFPerformance.com|
a853rox is offline   Reply With Quote
Old 10-02-2009, 10:15 PM   #75 (permalink)
nutz's Avatar
Trader Rating: (19)
Make sense?
do you think it will pull vacuum
Page generated in 0.16074 seconds with 13 queries
