Old 10-30-2009, 05:18 PM   #1 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Default Little help please....Cam seals
Well, finally got my car running, she sounds good with the new cams, built head etc. One problem....I'm leaking oil pretty bad from the exhaust cam seal.....Now, when I put the new cam seals on, I noticed one slide on the cam with ease, and the other was really tight to get on....wonering if the seal is suppose to be pretty hard to slide on the cam, or should they slide on with ease...little force.
AdvanSRT-4 is online now   Reply With Quote
Old 10-31-2009, 01:14 AM   #2 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (23)
well im sure you see it has that metal ring inside and the plastic type seal is a bit hard. i coat the ring inside and out with fresh oil. i press it on partically, but to get the seal more perfectly i use a big deep socket or a piece of exhaust tubing. i used the socket that fits on our axle's 31mm i use my hand and press it on there all the way.
GreaseMonkey69 is offline   Reply With Quote
Old 10-31-2009, 04:06 AM   #3 (permalink)
Member Number: 9751
they slide on fairly easy, i have had this happen to me also where i rolled the inside of the seal when installing it, i would take it off and repalce it with a new seal.
****Second street Srt-4 in the 9's 9.95@143****
Time to make some BIG power
kevinwarren240 is online now   Reply With Quote
Old 10-31-2009, 10:04 AM   #4 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
^^X2. I have done that more than once. Its a pain in the ass but it has to be replaced. I normally put a little bearing grease on it now before I slide it on and it works well. If it rolls or gets a little nick in it, just throw it away and get a new one before you put it back together because it will leak.
porksword is offline   Reply With Quote
Old 10-31-2009, 11:04 AM   #5 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
Ya I think that's what might have happend, I could of rolled the seal on it, or nicked it.
Thanks fellas.
Old 10-31-2009, 12:19 PM   #6 (permalink)
Trader Rating: (23)
i think i have like 4 extra sets of them it is from all the head gasket kits i ordered and never needed anything else
Old 10-31-2009, 02:41 PM   #7 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
Got the old seal out, and there was a defect in it. there was a hairline crack in it.
Got a new Fel-Pro one for $6 and about to slap it in.
Old 10-31-2009, 02:44 PM   #8 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
good deal. my wife dressed up as wonder women, pretty hot lol
AGP S256 FS
Old 10-31-2009, 03:00 PM   #9 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
bs without pix
Old 10-31-2009, 03:27 PM   #10 (permalink)
lyncoo's Avatar
Trader Rating: (92)
Quote: Originally Posted by nutz View Post
bs without pix
ill get them up
Old 10-31-2009, 07:06 PM   #11 (permalink)
AdvanSRT-4's Avatar
Trader Rating: (57)
Ya I got it all in, all was good and I got distracted by 2 of my buddys (assholes) and forgot to tighten the cam gear bolts. FUUUUUUUU! Had the car idleing for about 2mins, then I realized I forgot to tighten them.....about 1 sec from killing the ignition, it backfired, and the engine stopped. Just need to re-time it tomorrow.
Coors, pics please sir!
Old 11-01-2009, 05:48 PM   #12 (permalink)
porksword's Avatar
Trader Rating: (21)
Subscribed for wonder woman pics.
AdvanSRT-4, glad you got it fixed.
Page generated in 0.14436 seconds with 13 queries
