Old 09-22-2006, 06:02 AM   #46 (permalink)
SinceNine19's Avatar
Member Number: 5122
Trader Rating: (20)
Thanks
(uncommonsales formerly and agilesrt) lol.
SinceNine19 is offline   Reply With Quote
Old 09-22-2006, 09:37 AM   #47 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (378)
However you guys do know that you dont have to take the timing belt off when just changing the cams? If your doing cam gears or valve springs thats a different story.
Look for 9s with a manual very soon!
10.62@133.8
10.64@136.7
CSRT4 In house! http://www.caliberforums.com/forums/...ead.php?t=5153
Old 09-22-2006, 10:15 AM   #48 (permalink)
Member Number: 5122
Trader Rating: (20)
I noted in mine not to remove it completely. We just pulled it off the gears and set it to the side a little, then wrapped it back on the new ones easily afterwards instead of taking it all off. Saved a lot of time I know heh.
Old 09-23-2006, 05:50 AM   #49 (permalink)
lilturbododge's Avatar
Member Number: 24594
half way done....got the cams out last nite, and today is the day....after work i will get it done....btw, these suck to take off!!
Good-bye pistons, Hello Rotary
lilturbododge is offline   Reply With Quote
Old 10-16-2006, 06:54 AM   #50 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
bump for some new added info to the sticky.
At one time I was really keeping this updated but over time, well you know. If anyone see any added info that would help out PM me or post up so I can get it on here. Others have PM stating that it's helped alot. I'm going to try to revise the sticky.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline   Reply With Quote
Old 12-03-2006, 12:53 AM   #51 (permalink)
towsrt4's Avatar
Member Number: 37591
Pictures would be awesome I plan on doing 2.0l cams with cam gears in a few months and pictures would be awesome. Does anyone know if there are pictures in the service manual? I plan on buying one but if someone here who has one could scan in some pictures of the cam removal process and or install that would be kick ass. Thanks
towsrt4 is offline   Reply With Quote
Old 12-04-2006, 07:25 AM   #52 (permalink)
on the service manual there is pix in there, but they will kinda confuse you...i downloaded mine off the web, just google it, and im sure you will find a pdf file...good luck on the side plate, i swear it took me 3 hrs to move it out of the way, i was never able to fully remove it, but i did get it out of the way to remove all the bolts and stuff....if you have never done anything like this, i would alot for about 12 hrs for removal and install....
Old 02-16-2007, 12:34 PM   #53 (permalink)
Member Number: 31574
Trader Rating: (31)
bump for pictures! lol.. i understood most of it.. there is so many things to remove it gets confusing though!
Boost gets you laid.
black srt4 05 is offline   Reply With Quote
Old 04-03-2007, 11:27 PM   #54 (permalink)
Member Number: 48407
Trader Rating: (20)
Add to Sticky?
good luck
Pussies will never be hero's!
Pride-In-Precision is offline   Reply With Quote
Old 04-11-2007, 06:24 PM   #55 (permalink)
RickySRT's Avatar
Member Number: 30431
Trader Rating: (18)
^^^ Thanks for the useful info. I look foward to the task of installing my BC S2 cams sometime soon when I have another long weekend.
RickySRT is offline   Reply With Quote
Old 07-12-2007, 11:05 PM   #56 (permalink)
cbsrt403's Avatar
Member Number: 7299
Just finished with the install of the 2.0 cams and timing belt the thread really helped. Thanks for the info IT REALLY HELP A LOT. As for the special tool autozone has it part number 27139 60 dollers to loan but definatly needed for this job. While i was at at also installed water pump, new clutch, rear main, cam seals, the rest of the belts and timing cover seal. Again thanks for the write up.
EVOLVE THIS!!!!!
cbsrt403 is offline   Reply With Quote
Old 11-06-2007, 01:12 AM   #57 (permalink)
ACeR's Avatar
Member Number: 49468
Don't see any write-up on page one.... It's just not there. Everything seems to be in place, but there is no write-up. I don't understand.
The Mystery Skittle - Sold
ACeR is offline   Reply With Quote
Old 11-26-2007, 03:28 AM   #58 (permalink)
Member Number: 26483
yeah.. where's the write up?
Ninjaneonturtle is offline   Reply With Quote
Old 11-28-2007, 07:59 PM   #59 (permalink)
Trader Rating: (37)
When I was trying to edit the post it got deleted some how. I have contacted several of the moderators and admins and can't get a response back.
ATTENTION ALL -
If anyone saved the post please me me a copy so I can post it back up
Old 12-18-2007, 06:19 PM   #60 (permalink)
moparmansrt4's Avatar
Member Number: 50684
Anyone? This suxors Fo Sho!
Quote: Originally Posted by rollwitstyle View Post
the srt is the worst car to buy it sucks so much balls and tastes like doo doo. buy the t/a they are the fastest cars ever and they taste like steak....... by the way pm me atleast a week in advance if you plan to visit ny
http://www.srtforums.com/forums/f106...ml#post5894846
moparmansrt4 is offline   Reply With Quote
