Old 05-19-2007, 07:17 AM   #16 (permalink)
SRToc Member
neonmarine's Avatar
Member Number: 21010
Trader Rating: (32)
wheres the STICKY!
neonmarine is offline   Reply With Quote
Old 05-19-2007, 08:59 AM   #17 (permalink)
Super Moderator
1badsrt-4's Avatar
Member Number: 21276
Trader Rating: (53)
Nice write up!!!! stuck
11.34 @ 128.33 mph. Stock motor, head, cams and ecu
1badsrt-4 is offline   Reply With Quote
Old 05-26-2007, 10:52 PM   #18 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (21)
WOW! Great job on this. I'm doing mine in the next weekend or so. I was looking for something like this. Thanks!
04 S3 11.90@113
Old 05-26-2007, 11:57 PM   #19 (permalink)
Annihilator's Avatar
Member Number: 42629
thanks for the writeup! I had been looking at doing the 2.0 cams setup, I might go for it now that I have something to refer to. Even though it's a big job, it looks doable.
I know it's best to tune on the dyno, but is there even an alternative aside from pure guesswork? Like, could you do it based on something that is reading knock retard? Just curious. I ask because we don't have any decently priced dynos in my area that I'm aware of.
Annihilator is offline   Reply With Quote
Old 04-06-2008, 04:44 PM   #20 (permalink)
catlin987987's Avatar
Member Number: 55516
Just to let everyone know you MUST put on cam gears on, some might think you don't need it put, we lost alot of power higher end with out cam gears, might I even say the car is slow with the 2.0L cams (Now am gears are on the way).
2004 E-Blue
catlin987987 is offline   Reply With Quote
Old 04-06-2008, 05:05 PM   #21 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (15)
I noticed a huge drop in top end with 0/0. With the exhaust significantly retarded and the intake slightly advanced, there was a pretty nice gain in the top end from factory 2.4l camshsafts.
Powered by Turbonetics, South Bend Clutch, Wiseco, Crower, PTP, Realtune, Pwerks, SCT, DSS, AGP, HKS and some 93 octane!
Old 04-10-2008, 09:53 PM   #22 (permalink)
iblue's Avatar
Member Number: 814
Don't use RTV on the cam caps, you are supposed to use anaerobic sealant. That is the type of gasket maker that is refrenced in the FSM.
1999 Neon w/2.4 Swap - 2003 SRT-4 - 1988 Mustang 5.0 LX Vert
Its a love affair, mainly Jesus and my hotrod.
iblue is offline   Reply With Quote
Old 04-11-2008, 12:23 AM   #23 (permalink)
rasp's Avatar
Trader Rating: (15)
Don't recall ever using sealant on the cam caps...
Old 04-11-2008, 12:30 AM   #24 (permalink)
Member Number: 58932
wait, i thought you said my opinion changes all the time?
dont i say 0,0 hurts top end?
didnt i mention from the getgo +i,-e?
Old 04-11-2008, 09:29 AM   #25 (permalink)
iblue's Avatar
Member Number: 814
Well, you are supposed to.
INSTALLATION
CAUTION: Ensure that NONE of the pistons are at
top dead center when installing the camshafts.
(1) Lubricate all camshaft bearing journals, rocker
arms and camshaft lobes.
(2) Install all rocker arms in original positions, if
reused.
(3) Position camshafts on cylinder head bearing
journals. Install right and left camshaft bearing caps
No. 2 – 5 and right No. 6. Tighten M6 fasteners to 12
N·m (105 in. lbs.) in sequence shown in (Fig. 35).
(4) Apply Mopart Gasket Maker to No. 1 and No.
6 bearing caps (Fig. 36).
Install bearing caps and
tighten M8 fasteners to 28 N·m (250 in. lbs.).
Old 04-11-2008, 10:58 AM   #26 (permalink)
rasp's Avatar
Trader Rating: (15)
99% of your content changes weekly or monthly. You're simply a very unreliable source for anyone and honestly have zero business adding your input outside of your homoerotic California thread. Simply because your ass could feel a change in top-end power with the 2.0l cams means squat, then you prance around and act like you're the only one who's tuned 2.0l cams.
I'm not the only one who knows what you say half the time is utter crap; your opinions shouldn't even qualify as valid. Now hurry, go make another thread in your California forum! It's always nice searching for new posts and seeing that you've done jack with your day but sit and make new random threads in your regional forum.
Old 04-11-2008, 11:02 AM   #27 (permalink)
right, cus when i gain 15-20hp everywhere, and 25 at redline, it means jack squat when i had the dyno graph to prove it.
and youre singing the same ol song.
glad you're checkin the cali section out. keep peepin us!
boringgggg
btw, got a thread for u in the cali section.
Old 04-11-2008, 11:24 AM   #28 (permalink)
rasp's Avatar
Trader Rating: (15)
Pansy rebuttal. I shouldn't expect any more out of someone of your pathetic stature, though.
Old 04-11-2008, 11:32 AM   #29 (permalink)
Old 04-11-2008, 12:53 PM   #30 (permalink)
cokey's Avatar
Member Number: 17219
Trashen up the thread people..
?, I knw nothing about cams, why are 2.0L cams better then out stock? What advantages do they offer..?
mike, itzcokey@aol.com
FS drive side head light $50 + shipp (obo); stock ic $60+ shipp; silver wing perf cond 100$ obo; crash bar 50 + shipp; stck cold side
makeover http://www.srtforums.com/forums/showthread.php?t=345296
cokey is offline   Reply With Quote
