Old 05-01-2008, 05:02 PM   #46 (permalink)
raven's Avatar
Member Number: 10177
Trader Rating: (42)
Quote: Originally Posted by StageSRT4 View Post
yea i figured. I have my buddy Raven coming by to lend a hand, but weve never done 2.0 cams. At least i have 1-1.5 hours on the dyno. I kept the boost down, cause im not trying to tune the car as well. 21psi will do for now.
that guy doesn't know shit, i would never let him wrench on any of my cars...
Quote: Originally Posted by aaronneon@RealTune View Post
Its Raven. He is world famous.
He also carries a sign that says, do not feed the animals
raven is offline   Reply With Quote
Old 07-16-2008, 09:30 PM   #47 (permalink)
Member Number: 27249
now this is just a random neons.org person question but when you put 2.0l cams on a 2.4 n/a you have to cut the nipples off the cam magnetand turn it 90degrees then tighten it back down....do you not have to do this on 2.0l going into a srt or am i missing when people have been talking about that?
TwistedTunerz is offline   Reply With Quote
Old 07-16-2008, 09:32 PM   #48 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (15)
The bottomline is, that when you have the engine TDC. The cam magnet has a marking or a slit if you will. That slit\marking lines up at about 5pm.
I got's a fuel cell......................what you got?
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 07-16-2008, 10:09 PM   #49 (permalink)
huh..... anyone have any pics of this part of the install....when i did a 2.4 swap into my 97 neon you had to snip off the nipples or your timing would be off....you cant just have them at "5pm" there are nipples that will only go in one spot and the only way to adjust it is to cut off the nipples and rotate the mag. 90 cam degrees(180 crank degrees)
Old 07-16-2008, 10:19 PM   #50 (permalink)
Trader Rating: (15)
you also had to cut and switch 2 wires at the coil.
look at your cam magnet
notice the 1 and only marking\slit
that slit will be at 5 o clock when engine is ATDC
before you put cam position sensor back on.
it will all line up for you in the end!!!
Page generated in 0.30427 seconds with 11 queries
