Old 04-24-2008, 09:28 PM   #1 (permalink)
SILLI G's Avatar
Member Number: 41536
Default Help. Timing belt issues?
Hello everyone im not sure if this place is the place to post for questions about timing belts but any help would be nice. Hello im at 94k the past couple of weeks i have been having this prob whn i try n floor it the car at WOT will just fall on its face. I have been hearing some belts squeak a bit also. But my real problem is that i was driving to school i pull up in the parking lot my car makes a grumbel n cuts off on me. I act cool and just coast into my parking spot. The car wont turn over for anything u hear the starter try n turn the car on n see the serpintie belts move. the battery is fine but i took a peek and the timing belt isnt moving. I think the timing belt is gone i havent took the cover fully off but i have come to grips that its gonna be that. Any info would be HIGHLY HELPFUL please help and thank you every1 in advance.
Mopar BOV, Mopar STS w/ booger bushings, Maxx
Fab 3in Downpipe w/ Mopar Borla Catback, Mopar Stage 1 , JMB Cold Air Intake, AGP wastegate spikes17 holds 16, Lowered, BFMIC an no boost leaks ... n more 2 come
SILLI G is offline   Reply With Quote
Old 04-25-2008, 04:40 AM   #2 (permalink)
SILLI G's Avatar
bump plz
Old 04-25-2008, 05:21 AM   #3 (permalink)
Member Number: 11814
Trader Rating: (91)
Best advice is to get it to a mechanic/dealer and have the belt replaced or are you looking for advice on how to change it yourself? If so theres some threads dealing with servicing the belt along with info in the factory service manual.
turbojack is online now   Reply With Quote
Old 04-25-2008, 06:31 PM   #4 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (15)
If the belt isn't moving it most likely snapped or the tensioner pully seized up and the belt is just hanging there. Follow a camshaft install guide to replace them. S&P sells the belt for like $55+ shipping or something and the tensioner can be bought from them, too. They're a vendor.
Or you can lube up your bum and pay for DCR's billet tensioner.
I love turbo lag, it gives you a second to reflect about the poor decision you have just made.
rasp is online now   Reply With Quote
Old 04-25-2008, 06:34 PM   #5 (permalink)
lunchbox660's Avatar
Member Number: 10098
Trader Rating: (31)
um....if the belt isnt moving at all im surprised your car even runs at all... are you sure youre talking about the TIMING belt and not one of the accessory belts, like the one that runs the alternator????
lunchbox660 is offline   Reply With Quote
Old 04-25-2008, 06:41 PM   #6 (permalink)
rasp's Avatar
Trader Rating: (15)
He said it made a grumble and shut off on him, and he wasn't able to restart...so the car does not run...
Old 04-26-2008, 10:16 AM   #7 (permalink)
SILLI G's Avatar
thxs yea my car isnt running at all it will struggle but never turn over i had wild ride of towing my car back home using only straps tied to my frame being pulled by another neon. But im am walking downstairs right now about to rip apart the car and see what happened hopefully its just the belt and hopefully this doesnt take me all day.
Old 04-26-2008, 01:41 PM   #8 (permalink)
SILLI G's Avatar
ok im moving slow im realizing there isnt much room 2 work here. i have the car on stands. taken off the passenger wheel and dust guard. Now i have fought with the top timing belt cover i have that off now. As of now i have 1 of the bottom scrws off from the splash gurad off. I think the belt may be bad becasue i see like rubber dust shavings on the cam gears its not a little bit its a nice little pile. Im taking my time trying to do this right i'll keep it updated if anyone wants to chime in on anything im on a water break thxs
Old 04-26-2008, 05:46 PM   #9 (permalink)
SILLI G's Avatar
Default Helpz
ok now i need help any one. i took the seprtine belts off and i have the all the screws to the lower splah/dust cover to the timing belt off but i cant take the cover off without taking the underdrive pulley off how do i do that if the pulley wheel keeps spinning HELPZ thxs
Old 04-26-2008, 05:55 PM   #10 (permalink)
Member Number: 41738
You are going to need a service manual if you want to do it right. This is not a job to just try and figure out on your own.
Srtsi4wd is offline   Reply With Quote
Old 04-26-2008, 05:57 PM   #11 (permalink)
SILLI G's Avatar
im using an online one and still would like some advice to even get to the belt and the crank pulley off
Old 04-26-2008, 06:13 PM   #12 (permalink)
You will need a 3 jaw puller and an assortment of washers. You will also need a bolt with the same threads as the crank pully bolt but longer to reinstall the pully.
Old 04-27-2008, 12:12 PM   #13 (permalink)
SILLI G's Avatar
Hey thanks i had 2 rent that 3 prong crank puller tool from Advance Auto parts for free that was good but my pushrod wasnt long enough so i got a steel screw and cut the head off and used that back up against my push rod and a couple of turns n pop goes my crank pully yay. After that i took off my lower dust/splash cover thing n it revealed my timing belt which is gone. I couldnt pull an all nighter i went 2 a party. But today I have to get everything lined up play with the tenisonmeter and install this new belt. the only thing is how will i get everything lined up if the belt is stripped and i can only turn from the crank? thxs for the help im posting pics in abt 3 min
Old 04-28-2008, 04:56 AM   #14 (permalink)
SILLI G's Avatar
Hey great news and thxs every1 i changed the belt last night with a little help from my pops we got this thing working all i have 2 do is my wheel back on and a dust cover and im game. I thx u for your help thxs every1
Old 04-28-2008, 05:33 AM   #15 (permalink)
SILLI G's Avatar
http://i222.photobucket.com/albums/d...ar/badbelt.jpg
BAD BELT^
Page generated in 0.32695 seconds with 11 queries
