Old 06-27-2009, 07:31 PM   #1 (permalink)
99dohcneon's Avatar
Member Number: 48910
Default Head install
Head has 10k after rebuild. Do I need to install new valve seals? (I bent the valves) Also should I shave the head down? I figured I needed to.
'99 neon 2.4 swap w/2.0 cam, 60mm tb, afx race ecu, sts, exhaust, p&p intake mainfold etc....
'98 neon rt srt swap w/20g turbo ran on MS 18psi Project log http://forums.neons.org/viewtopic.ph...70409#p2770409
http://www.cardomain.com/id/the_game_rock
99dohcneon is offline   Reply With Quote
Old 06-28-2009, 09:46 AM   #2 (permalink)
Darthmopar's Avatar
Member Number: 40046
Trader Rating: (36)
If you are having it rebuilt you should replace the seals anyway, and I wouldn't surface it unless its warped.
The boost is strong with this one
Darthmopar is offline   Reply With Quote
Old 06-28-2009, 03:18 PM   #3 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (23)
you can get stock valve seals from S@P development good prices
GreaseMonkey69 is offline   Reply With Quote
Old 06-30-2009, 10:08 PM   #4 (permalink)
99dohcneon's Avatar
How do you use to check?
Old 07-01-2009, 10:44 AM   #5 (permalink)
BDCarrillo's Avatar
Member Number: 59014
Trader Rating: (13)
Straightedge and feeler gauges. Do the straightedge diagonal from the lower left corner of the head to the upper right, then upper left to lower right, then straight down the middle. At each position try to wiggle a feeler gauge under the straightedge.
Most machine shops should be able to check it also
Pony - 1989 5.0 LX Convertible - 200hp/266tq old 302
Ol' Girl - 1971 Mach 1
Skittle - 2005 SRT4 - 229hp/259tq stock 281/327 stg2 12.6@114mph
BDCarrillo is online now   Reply With Quote
Old 07-01-2009, 11:13 PM   #6 (permalink)
99dohcneon's Avatar
Ok thanks.
What about valves guides? Do I need some?
Old 07-02-2009, 01:10 AM   #7 (permalink)
Trader Rating: (23)
was there any bent valves? the valve guides should be just fine. if you want a machine shop to check them and if needed de-burr them im sure they will, but i don't see valve guides really getting replaced much.
Old 07-02-2009, 07:03 AM   #8 (permalink)
BDCarrillo's Avatar
Trader Rating: (13)
Ok thanks.
How did you bend the valves, and where did they bend? If ANY valve STEM was bent about 1/4" above the valve, get the head checked by a machine shop, as some of the guides may need replacing. Also, if any of the valves had to be forcibly removed, get the guides checked
To check the valve stem, roll them on the edge of a flat surface by hand.
Old 07-02-2009, 10:17 AM   #9 (permalink)
99dohcneon's Avatar
Timing belt broke. Ill have to look and see. They are barely bent. I think they bent towards the bottem. Compression was 0, 150, 160, 160. They came out easy no force was needed.
Old 07-02-2009, 11:54 AM   #10 (permalink)
BDCarrillo's Avatar
Trader Rating: (13)
Then you OUGHT to be good. As a test, lightly lube a new valve stem and stick it in the guide from the top, without the seal in place. Make sure it's all the way in the guide, and try gently wiggling it in all directions. If all the guides have the same amount of "wiggle" room (if any) then they should be good.
Also, use a bright light and look for scoring or evidence of abrasion in the guide itself.
Since the valves bent towards the bottom, you can also look for small chamfers worn in the guide from the bent stem, looking at it from the combustion chamber side.
If all of those tests come out OK, then they should be just fine.
Old 07-02-2009, 02:39 PM   #11 (permalink)
99dohcneon's Avatar
Alright thanks.
What kind of valve spring compressors do you use on these heads?
Old 07-02-2009, 04:36 PM   #12 (permalink)
Trader Rating: (23)
lucky i had a friend who was a dodge tech he let me use thier valve spring compressor. it was made specifically for our heads.. im sure a machine shop would have a valve spring compressor to help you remove the springs.
Old 07-02-2009, 10:10 PM   #13 (permalink)
99dohcneon's Avatar
I got the springs out. I just have to get them in. (hammer) I seen people use a $20 craftsman one and they added a socked with a window in it. It works good from what I hear. I was seeing if there was another way.
Page generated in 0.19504 seconds with 13 queries
